Question about Microsoft Xbox 360 Console
Xbox 360 error code 0002
Hello
i have replaced my clamps all seemed to go really well but now i have got the error code 0002 network error.
does this mean that the internet connection socket has unsoldered or is it something more than this.
thank you
  • 11 more comments
  • oldest fart Jan 06, 2008
    thank you for the information
    i have just added the little aluminium shim and respaced it accordingly and all seems fine now but if it goes again then its time to have a go at melting the solder on the chips.
    thanks for all your help
    daz
  • knowledge101 Apr 03, 2008
    I have the same problem . I did the x-clamp, heat gun, artic silver 5. Now when the 3 red lights come on, it gives me this 0002 secondary code since the screen is blank. What' s the deal w/ the aluminum shin? Anyinfo will greatly help! Thank you, J.
  • Anonymous May 21, 2008
    I am getting error code 0002.  When i turn the power on the xbox i get the 3 red lights, but nothing else really works.  The DVD drive and the fan don't turn on and the power brick's light is yellow, which i know means that it is on standby.  I know it is not a problem with the powerbrick because xbox sent me a new one and the same problem is still happening.  the powerbrick is on standby and the only thing really working on the xbox is the 3 red lights.  Any help is greatly appreciated
    I've fixed that same problem many times with an XBOX 360 Repair Guide from www.BestXBOX360RepairGuides.net/?key2=macro77
    You can easily repair any XBOX 360 in less than an hour with this repair guide. PLUS it has follow along Videos.
    Don't buy any guide yet you can get all the info on this free blog of what to do!
    Check out a FREE blog first that will tell you how to fix it so it is fixed permanently:
    I fixed it easy using this free blog:
    http://xbox3603redlights.wordpress.com/
    Read this first!
  • Anonymous Nov 09, 2008
    15e4tretr45rtre
  • travieso1208 Nov 09, 2008
    hykjk
  • Anonymous Jan 21, 2009
    When I pull it out It work fine And when i put it in it does not work
  • jmeeks Jan 22, 2009
    I have an error code 0002 when I power up the console power brick clicks to red and 3 rod. x-clamps have been replaced and pretty sure I did a good job heat gunning the cpu and gpu.
  • Anonymous May 17, 2009
    how did you fix 0002
  • ursemboys May 21, 2009
    i have also got error 0002 ,after i did the clamp mod ,i powered up the xbox and it worked fine no lights and full profile visable .i then refited the case and powered up again and now three lights and error code 0002
    please help its doing my head in
  • ilahaa May 11, 2010
    Solution Link . . . www.MicrosoftXbox360Console.com`
  • Ryan Hutchison Aug 08, 2013
    I get this code when my Xbox has to re-boot. Like after a system update when your Xbox switches off and then back on. But the initial startup has no problems and I can still use it.
    Scholar:
  • 64 Answers
So far there is 1 major theory for what causes most of these errors is that the Ram, CPU, or GPU are not soldered properly to the mother board due either to poor manufacturing or excessive heat up and cool down cycles that stress, weaken and eventually break the soldered connection. Error code "0002" is a Network Interface problem. Since you have already replaced the clamps (I'm assuming your talking about the "X" clamps) there is only one other thing that might bring it back to life is re-heating the chips, sounds odd but has worked. Use a heat gun and slowly heat up the chip's, be careful not to overheat them. Try turning it on and see if anything changes, do this every so often until you get the results you need. REMEMBER< DO NOT OVERHEAT OR MELT THEM, USE CAUTION ANS COMMON SENSE. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
If this doesn't work you may have to get a new one.
Posted on Jan 06, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 97 Answers
Shim method...buy a piece of very thin aluminum from your local hobby shop. then cut it with a dremel the same size as your two chips on the gpu. liberally apply thermal paste on gpu and shim. replace heatsink, tightend screws(if you replaced clamps) and let it run for a few mins if it doesnt fire up immediately. the shim applies even pressure to the proc on the mobo which forces a connection to the bga(ball grid array). i've tried it on a few unrepairable xbox's so far and they have come back to life! good luck
Posted on Jul 30, 2008
For the shim method would a piece of aluminum can work?
Posted on Sep 08, 2008
What is the shim method??? I tried the x-clamp method and now it gets error code 0002- nothing turns on but the 3 red lights I tried to loosen the nuts and tighten and nothing. What is this shim mthod you are talking about???
When you say heat up the chips you mean the cpu and gpu while the heatsink is on? Or you mean heat up the southbridge chip?
Posted on Jun 04, 2008
Try loosening the clamps ever so slightly. I had mine too tight & received the same error. A couple twists of the screwdriver & voila!
Posted on Jun 02, 2008
I read some were that its the fuses on the 360 motherboard blow and thats why you get error 0002. i dont know were the fuses are on the motherboard. maybe some here might know
Posted on Jan 08, 2008
I am also having the same problem. no power, only 3 red lights come on. Any alternatives if you don't have anything to re-heat the chips?
Posted on Jun 07, 2008
What dose code 0002 means in canon mf4410
Hi the only error codei i could find for this model MF4410 printer .,is E202-0002 fault description ::: contact sensor HP error,Failure in return remedy. Check connection of flat cable between main control board (J5) and contact sensor . (2) replace flat cable between (J5) and contact sensor (3) replace the contact sensor (4) replace the main controller board.:::: good luck
May 02, 2016 | Canon Office Equipment & Supplies
Error 0001 error 0002
I have looked through the Service Manual for you and there does not seem to be an error code 0001! or 0002. Are you getting any sound Bleeps? Or flashing Orange or Green lights?
Mar 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
Error code E0000001-0002
That's a fuser temperature code that will need to be cleared in service mode. Press the additional functions key * then press 2
Mar 13, 2012 | Canon imageRUNNER 2200
E000070-0002
this error is for ITB belt( transfer belt ). Probably because it needs to be changed along with the ITB cleaning blade.
In error, the 0002 means that second sensor cant read the Itb belt.
As first aid, you can clean the back of the Itb belt and the driving roller.
Hope that helps!
May 01, 2011 | Canon imageRunner C3100N Copier
How do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
tomas
how do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
Solve this problem:
Aug 02, 2010 | Epson Stylus Pro 9600 InkJet Printer
Hello, i have a hp notebook which code 31 error on
http://support.microsoft.com/kb/932520
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
Feb 23, 2010 | HP Pavilion dv6000z Notebook
Hi sir
0002 Network Interface problem
May 31, 2009 | Microsoft Xbox 360 Console
What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
Product : imageRUNNER C2880 / C3380 Title : E025 sub code 0002
Problem :
The machine is giving an error code of E025 with a sub code of 0002 indicating an error with the cyan toner motor.
Solution :
Replace the Process Kit Relay PCB. Item 58 of the Hopper Assembly circled below, part number FM2-8266-000. NOTE: the service manual refers to this part as the Process Kit Relay PCB while the parts catalog calls it the Connecting PCB Unit.
getfile.asp?rid=24817
Apr 27, 2009 | Office Equipment & Supplies
Xbox 360 code 0002
Go here you will fix your Xbox in 2 hours dont mess around you may do more damage http://xbox360repaircenter.info They help me out a lot
Oct 22, 2008 | Microsoft Xbox 360 Console
Xbox 360 0020 error code
here is a site i found that shows detailed fixes for this error with your 360's - here it is
Jan 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
17,504 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
