Washburn Wi14 Electric Guitar Logo
Anonymous Posted on Nov 09, 2009
Need to know what brand and size strings come standard on washburn wi-14
Anonymous
Level 2:
Scholar:
  • Expert 105 Answers
  • Posted on Nov 09, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
105
Questions
Helped
31885
Points
324
I would recommend that you visit a local music store and ask which strings to purchase for your guitar. Or CLICK HERE to se some choices on the internet. Good Luck. I hope you make a hit record!
Testimonial: "great advice"
Need a manual for a washburn wi64
I have a Washburn wi-64DL. The back what is normally tone controls have voc on the control pots. What is that
What would cause certain strings on my banjo to have a flat sound and not a ringing tone? These are a brand new set. thank you ...
The laws of physics govern this. The strings "ring" while they resonate. The time they resonate is related to the "Q" of the string or the efficiency. The Q is the enrgy stored divided by the energy lost per CYCLE of the oscilation. Strings that damp out quickly have a low "Q". This can be caused by any of several things thaat include anything that can dampen the oscillation. String quality is important as well as secure attachemnt at each end and proper placement in the nut at the head. See if you can find anything that creats drag INCLUDING string height that affects the windage as they vibrate. First place to look is at the resonator end. Are the strings well attached at the end? Is the bridge properly placed and setting tight on the head? The bridge often has offsetss for some strings... check that it is properly oriented. I will refer you to videos on banjo stringing on YouTube, They can cover much more than we can here using text.
How to replace the guitar strings
Search on YouTube.com There are some good videos of exactly how to do it!
1helpful
2answers
Washburn guitar B and high E string sound real buzzy-tinny. am fretting it clean. It just started doing it. Any Help?
Probably time for string replacement !!! They do go bad...
Get a set and try the E string... if it fixes that one, change ALL the strings at one sitting, but do them one at a time and tune each as you go... this keeps the tension and minimizes the interaction when you do the final tuning.
2answers
Both the E and A strings of my Washburn acoustic guitar "BUZZ" even when lightly strummed. The guitar has "light" (.012 - .053) Phosphor Bronze strings.
Buzz usually translates to either inadequate fret clearance or poor quality strings or inadequate pressure holding strings against the fret.
The guitar DESERVES using high quality strings and I would look at the manufacturers recommended string weight or your music store should know what to use. The LIGHT strings MAY be your problem.
1helpful
I have a washburn WI 14 guitar and trying to change pickups. the old one is two wire. white and bare. the new one have like 5 wires. anyone replace the pickups in their wI 14?
This is the way most aftermarket pickups are set up. Its to accommodate different wiring setups like coil splitting.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
Whether the pickup is a Duncan or not does not make a difference. Make sure you solder the red and white wires together(the ones together in the diagram) and cover the joint with heat shrink or electrical tape.
String peg required for washburn d10b
http://www.stevesmusiccenter.com/EZPeg.html
A new type of peg that makes it easier to change strings!
Either that or most guitar shops stock string pegs, Just ask at the counter .. .If they don't have them and can't get any in then they are not a real guitar shop in my opinion
3helpful
2answers
What kind of strings are best for washburn X 10
the washburn X10 is an electric guitar.
first thing you you want to make sure of is that you ask for electric guitar strings
next consider what kind of music your are playing...
heavier music or really moody warm tones your going to want thicker strings
med to heavy guage
if you want clear crisp tones than go with lighter guage
light to med
lighter guages are also easier on the finger tips.
the sizes usually refer the the smallest string on the bottom or the first string.
9 is the light 10-11 is med 12 is heavy
you might also want to consider nylon coated strings
they last longer
have great tone
easy on the fnger tips
but they cost more
Top Washburn Music Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Are you a Washburn Music Expert? Answer questions, earn points and help others
