my pictures are out of order, they used to be in chronological order but now i have to search through older pictures to find pictures i have just taken. how can i fix that?
First, are you trying to view the photos on your camera, or is this after you've downloaded them onto your computer?
I took a look at my Cyber-Shot and it looks like it sorts photos strictly by the numbering sequence, not by date. I couldn't find a way to prioritize it to view by date in the playback menus either. Have you tried viewing them in index mode? You can do this by pushing the "Home" button while in playback mode. From there you can pick either single, index or slide show mode. If you have already tried this, do the photos still show up out of sequence?
If you are trying to view your photos on your computer, it's a simple fix, and it's only slightly different from Mac to PC. When you have the folder open containing all the photo files, simply click on the field at the top of the columns that you want to view them by, i.e., "file size", "file type", "date modified", etc.
My Sony-Cyber shot DSC-W55 display is so dark that you can hardly (it's almost impossible) make out...
(More)
My Sony-Cyber shot DSC-W55 display is so dark that you can hardly (it's almost impossible) make out the image when reviewing photos. When taking a picture you can see nothing but black. It takes photos just fine when looking through the little glass view finder. What has happened to the display?
When turned on, Access comes up on screen, and lens goes in and out several times, then screens says...
(More)
When turned on, Access comes up on screen, and lens goes in and out several times, then screens says to power off then on again, This will repeat when powered off and on again and so on.
Having a problem with my Sony Cybershot DSC-W55. When I power on, I get the Access screen and...
(More)
Having a problem with my Sony Cybershot DSC-W55. When I power on, I get the Access screen and nothing else. Camera tells me to power off and then back on, but nothing happens. Can you help me out?
my camera tells me to turn off and turn on again and it still does not work. how can i reset or fix...
(More)
my camera tells me to turn off and turn on again and it still does not work. how can i reset or fix it
