Home | Heaters | Hot water heater is mak...
Heaters
Problem for Heaters
Generic problem for all Heaters
Hot water heater is making a moaning noi...
By mark_harvey on Nov 09, 2009
hot water heater is making a moaning noise in the night.pressure is ok, rads have been bled & pump motor is quiet......any ideas?
Clarification Request
Posted by adamsaire on Nov 10, 2009
What do you mean by moaning? What is your system water pressure? How many levels in the building?
Solution #1
posted on Nov 12, 2009
Not Rated)
heatman101
Rank: Guru  Air Conditioners  Expert
Rating: 92%, 46 votes
You are hearing the pipes either expanding or contracting as they heat up or cool down. See if you can find where the pipe is rubbing a board or wall as it moves. this makes that sound.
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
What is the best portable heater for a 700 sq ft area
Answer
how can you buy things for less than what they ask for?
Answer
When turning on my Quadra Fire 1000, turn up the thermostat the orange light should come on... (More)
Answer
how do you install a 2 wire heat only honeywell thermostat?
Answer
I have a Trol A Temp MST (forced hot air) duct controller connected to HOneywell CM260 dial... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
