Question about Refrigerators
Refrigerator consisently buzzing...freezer defrosted overnight
Our Refrigerator was making a constant buzzing sound. We woke up this morning to a puddle of water coming from the bottom of the unit as well as the freezer being completely defrosted. We're not looking at buying a new one, but could it be the motor is not working at cooling the unit?
Thanks for your time....
    Sergeant:
  • 246 Answers
Not enough information to correctly offer , a diagnosis but, a buzzing sound could mean the compressor is attempting to start but can't. or it is running without freon. You will need a diagnosis from a certified technician for this issue.
Posted on Oct 19, 2017
aborcass
  • 2651 Answers
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Posted on Apr 02, 2008
  • 1314 Answers
SOURCE: Frigidaire Freezer Buzzing
thats not a valid model number open the fridge door and look up at the top by the light bulb on a white sticker and ill try to help ok
Posted on Apr 04, 2008
22yooper
  • 828 Answers
SOURCE: Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Posted on Jun 01, 2008
  • 1462 Answers
SOURCE: ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Posted on Aug 23, 2008
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
Yesterday morning I noticed that the unit was buzzing. The refrigerator door had been left open and the temperature inside was 70 degrees. The freezer temperature was 20 degrees. This morning, 24 hours...
Hi
You have condesation built up in your freezer whereby the evaporator fan or the vents are most likely blocked off.
Turn fridge off. Empty freezer and either put a pot of boiling water inside freezer or with the aid of a hair dryer try to defrost the freezer. If you are able to remove the back panel on the freezer that would be ideal as you can directly target the frost.
Good luck
Ash
Sep 06, 2011 | Refrigerators
Woke up this morning and the temp was at 70 degrees and it sounds like it is constantly running.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | True Refrigerators
Frezzer not Keeping things Forzen. I turned up the adjustment, and left it over night to adjust to new Temperature setting. I woke this morning to find everything almost completely Thawed. Fridge seems to...
heatman101
Mar 18, 2011 | Refrigerators
Whirlpool GD5SHA Freezer Problem: Yesterday, observed that freezer section was not keeping items frozen and the ice maker was not making anymore ice. The refrigerator section remained cold and the...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 17, 2010 | Whirlpool GD5SHAX Side by Side...
Ok I woke up this morning and everything was warm in my lg fridge and in the freezer.. I emptied it all out and now this afternoon it's working.. I had to throw almost all my freezer stuff away. :( Well...
Sometimes the defrost timer will stick and also...the compressor may not start right sometimes,,, its hard to tell exactly what the cause is...
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 08, 2010 | LG Refrigerators
My whirlpool side by side refrigerator was workin fine yesterday..when I woke up this morning it was not cooling and everything in my freezer has defrosted.. the light is on.. the water dispenses and it...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
heatman101
Sep 06, 2010 | Whirlpool GD5SHAX Side by Side...
The fan is running in the freezer constantly and frost is building up on the walls of the inside of the freezer. The fan is making a loud buzzing noise.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Maytag Refrigerators
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Water puddle on floor from inside refrigerator could it be defrost heateris bad? water accumulates in the bottom of freezer and freezes seems to come out of evaporator/fan location
unkink the drain hose...I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a galaxy fridge, side by side. it woke me up this morning making the LOUDEST noise! it sounded like it was coming from the motor underneath? i don't know a thing about refrigerators.... i just know...
Good day,
Motors make noise. There a 2 in the bottom back of the machine.
One is the compressor itself and the second is the cooling fan motor located in the same area. Someone will have to remove the rear bottom cover. If it's the fan motor, then the repair cost is nominal. On the other hand, if it's coming from the compressor itself, you have a major problem.
May 21, 2010 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
160 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
