My toshiba laptop turned itself off last night and won't turn back on. The power adapter is not the problem as we tested it on another comp. What could be the problem and how expensive would it be to fix? Thank you.
Try disconnecting your battery for about 10 seconds then reconnect the battery. Then plug the power adapter back into the computer if still no success hold pressure on the power adapter where you connect it to your computer. First hold it left then right then up then down while doing these tasks keep your eye on the ac light on your laptop and see if it ever comes on if it does it sounds like *********** board power connector has a short and needs to be changed if this is the case it is not to expensive a tech may charge you 80 to 100 to fix. If not its most likely internal and will probably result in a mother board change which can result in 100's of dollars
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Toshiba Satellite A135-S2386
i can not log to my account on my laptop and login passward is also correct but it shows only...
(More)
i can not log to my account on my laptop and login passward is also correct but it shows only loading on screen
