Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860 - H2O Error Code - Machine is asking for water but draining it straight out
Hi
my machine is constantly asking for water and draining it at the same time so only a little water goes into the drum.
any suggestions on whats wrong and if it an be fixed would be greatly appreciated.
thanks
  • 1 more comment
  • dgeyer Jan 07, 2008
    I have a whirlpool top loading washer and the same problem! It will fill and fill and fill and must be draining at the same time because it doesn't overflow and never moves on to agitate...could it be the water intake valve or the switch? HELP
    dhgeyer@esn.net
  • Anonymous Feb 10, 2008
    I have a WF 860 and is showing error code F08, please can you help, is this something that is easily fixed.
    Thanks
  • Anonymous May 21, 2008
    Machine bleeped in middle of a cycle and is now showing F-08. Tried switching of at mains and re-starting a different cycle but a several minutes error code came on again.
Check that your outlet pipe rises above the stated height on the back of the machine (about 3/4 of the way up). If it is too low, it will siphon the water out of the drum. If you're not sure what height it should be at, raise the top of the pipe (ie where it bends back into the outflow pipe) above the top of the machine (if you have room) or as high as you can. It must be above the height of the drum.
Good Luck
Posted on Jan 23, 2008
  • 139 Answers
I have an idea that it might be the waste pipe they are at ground level and gravity is forcing the water to exit beacause of this check to see if it is..
Also the hotpoint guy check your water pressure comming into the machine .. your fault code suggests that the water pressure is low.. disconnect the hot and cold pipe and check them to see if there is enough water pressure.. hotpoints are very prone to water pressure problems...
hope this helps if you need any other advice dont hessitate to ask.. ill try my best....
Posted on Jan 11, 2008
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
this m,eans the water is not entering the machine it iseither the inlet valve or water off at tap
Dec 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT960
its either a fill valve or you water taps are faulty ie; rounded off knobs easey fix please leave feedback good luck
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code h20
hi sounds like a faulty fill valve easy fix
H2o error
I checked everything I posssibly can and ended up booking an engineer who will be here Monday. I'll post what he says and whether or not it's DIY fixable.
Apr 03, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf640
Your exit hose behind the machine has to go over a certain height before it goes into your wall standpipe or sink. The height is marfked behind your machine, approx 3 feet above ground level. The hose should put about 3 or 4 inches into the standpipe, & not fitted airtight. Post back later if the code stil comes up...........
Mar 30, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
1,370 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
