Carrier XHB123D X/Y Series Heat/Cool BTU 12000/11600 Air Conditioner
Problem for Carrier XHB123D X/Y Series Heat/Cool BTU 12000/11600 Air...
My ac blows cooled air but my heater does not get
By mbmiles on Nov 09, 2009
My ac blows cooled air but my heater does not get hot
Solution #1
posted on Nov 09, 2009
Not Rated)
drberry
Rank: Guru
Rating: 92%, 83 votes
the heater coil has possibly burnt out. This coil is located behing the evaporator coil in the window a/c. To access the coil you need to pull out the unit from the casing. The coil looks like a toaster coil and is possibly in a metal box. Several screws hold the coil in place. If you are doing the repair yourself you will need to remove the coil take the model and serial number with you to an appliance parts house for replacement. Removal of the coil like i said before isn't hard however, you need to make sure all of the electrical wiring you diconnedct has been marked to insure you are placing the correct wires back in the correct location on your new heater coil. Good Luck on your repairs hope this helped you some
Dave
Was this helpful?
Yes
No
Popular Solutions for Carrier XHB123D X/Y Series
Questions and Unsolved Problems for Carrier XHB123D X/Y Series
Do you recommend Carrier XHB123D X/Y Series Heat/Cool BTU 12000/11600 Air Conditioner?
Answer
Answer
need owners manual for my unit or the wiring specs for it cant find the model number help on that... (More)
Answer
carrier ac model no cac 19 can i get wiring diagram please send by mail
Answer
Hi Just had a Carrier Infinity 96 (40000BTU) installed a few months ago in our 1500 sq ft home. My... (More)
Answer
where does the electric pilot hook up to the furnace unit. It seems my pipe has moved over the years... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air... Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
