Question about Sharp AR-5320 Black and White Copier
H4 error code
It happened only when our generator failed to continously working and it happened to turn on and off. before the last power shut-off i made a few copies from it and when the last power off this "H4" code blink on. please help on this. what does it mean? ive heard that some codes can be reseted, please if there is any what it is?
  • girlsgirls May 29, 2008
    does this error code have to do with the toner cartridge??
  • 146 Answers
H4 codes are related to the fusing unit. Specifically a low heat condition. Follow the reset procedure below. If that doesn't work further diagnosis of the fusing unit an peripherial circuits may be warranted.
Error code reset:
Perform the following key procedure
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Posted on Jan 06, 2008
Wounderful the code worked am so excited...... thanks
Posted on Sep 14, 2010
What is error code H4
Hi don the error code is a system overload. There are a lot of things that could be causing this temperature short circuit. Inwould take the cover of the unit and see if you can visually see any maybe dust or debri on any condenser coils or fans. If you can't figure it out call an expert.
Here is a link to the manual for your system
http://www.supco.com/images/Seabreeze/New%20Material%202011/NEW%20MULTI-ZONE%20INSTALL%20MANUAL%2012-10.pdf
Nov 28, 2014 | Cfm Klimaire KSWG009H113 Split System Air...
Tip
HOW TO REDUCE CHANCES OF H4 CODE IN SHARP COPIERS
The code H4 is common to all Sharp copiers. This occurs due to abnormal low temperature being sensed by thermistor. This means that the heater lamp which generates heat around the fuser rollers is either not working or producing very low heat. Low heat generated comes from low power output in the mains so, when you suspect low voltage, always switch off your copier and wait for normalcy. You can see from dim bulbs and know that's low voltage.
on Dec 02, 2009 | Office Equipment & Supplies
Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Jan 05, 2010 | Zoom H4 Handy Recorder
Sharp copier SF-2025 displays an error code H4
H4, not heating up, replace fuser unit complete or work with hivolts and replace an expensive and tricky lamp/thermister . wont be cheap.
. Here use the reset for it first, sometimes power surges can just flip them out but most times will just reappear shortly after reset, indicating the want of a working fuser assembly
Fuser (not fuse) is the hot bit with rollers at paper exit if code fails it needs to be replaced, wont come cheap no matter how you approach it
C-Exposure key-C-Exposure key-14-copy key to clear ... but it will come back I bet...
Nov 03, 2009 | Sharp SF 2020 Copier
Blinking h4 always
Hi:
Try pressing these keys in this exact order quickly. # * CLR * Then key in 14 and press start. Then turn off the copier and turn it back on. See if this clears you H4 error..
Good Luck
Andrew
Jun 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Xerox Workcentre Pro16fx - H4 error code after power outtage
You shut the machine off then on, Press Clear, auto,clear , auto, then when the lights go out, program it as if you were running 14 copies. press start and that should reset it.
Thats the redish pink clear button and the auto exposure button, Clear, Auto , clear auto, and the display goes blank , enter 14 and start. Dont ask me why I repeated that LOL
Feb 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Jul 26, 2008 | Sharp AR-C160 Color Copier
H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
Cant get rid of blinking error message, nothing works
The correct buttons to push in order to get into the service mode on a 162D are [#] key, [*] key, [C] key and [*] key. Then you key in 14 - 00 and press the Start key. If that fails to bring your machine back on, you'll have to replace the fusing assembly.
Apr 12, 2007 | Toshiba e-Studio162D Copier
Sharp AR-5320 Black and White Copier Logo
349 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
