Question about HP (J4107AABA) (J4107A#ABA) Print Server
Booklet Printing with hp LaserJet 1010 alignment problem
I tried to use Booklet Printing option in hp LaserJet 1010 on both sides of the paper. When I fold the A4 paper to get the Booklet, I found the alignment is missing and made the utility of that option useless. Help me solve this problem.
0 characters
1 Points
My print server cannot be reset to the factory default for some reason. I have tried holding the reset button for 10 secs, but without luck.
I have some devices where I have to hold the reset for 20 seconds. So try holding it longer. And make sure the print server is powered up when you do it.
Feb 17, 2016 | Belkin (F1UP0001) Print Server
How do I clear a paper jam when it is not reachable?
Call a HP service centre. They have specialist for these jobs.
Jan 15, 2015 | HP "LaserJet P2035n Printer"
Error 49.33.03
First turn off the printer and then delete the job held at the computer in the print queue. Then turn the printer back on. The error should go away. Try printing the document again to see if the error returns. Normally a corrupt print job causes this issue. If the error appears with no jobs being sent to the printer then the formatter board is most likely bad.
Mar 10, 2014 | HP Color Laserjet Enterprise Cp5525n...
Printing on HP Laserjet 1020 connected to the network through DLink DPR-1020 print server
did you resolve this issue , beacause have the same problem with a Toshiba e studio e223 ?
Jan 31, 2013 | D-Link Dpr-1020
Left edge black on hp laserjet printer
Fuser teflon sleeve got damaged, replace it.. (only professionals can do this activity) if its not available go for new fuser assembly..
Jul 31, 2012 | HP "LaserJet P2035n Printer"
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Print Servers
I have two printers to connect to my WGPS606. No
Hi, update the drivers for the printer 1010 on the concerned computer. If the issue persists then please perform the steps below to manually add the ports for the printer on the computer:
1. Go to control panel then go to printer and faxes.
2. Right click on the printer icon go to properties.
3. Click on the ports tab on the top.
4. Click on add port.
5. Select standard TCP/IP port and click on new port.
6. Press next.
7. Enter the ip address of the print server it will show you the port (IP_ip address).
8. Press next.
9. Select the second option custom and click on settings button.
10. Select the protocol as LPR, enter the queue name as q1.
11. Select LPR byte counting enable.
12. Click on ok and press next then click on finish.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 31, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Using HP Laserjet P1006. Is it compatible with DP-301U
Yes. I just got mine working last night. Key is to enable print services for windows through the control panel. Without that LPR printing does not work.
Jun 08, 2009 | D-Link DP 301U (DP-301U) Print Server
HP laserjet 1018 service
Have you installed the new drivers for your HP?
Personally, on all HP Printers, I use only HP products, mainly Jetdirect Print Servers, but you might try creating a TCP Port Printer (via your Printer Install Wizard) and use that. You only need to know the IPAddress of the DLink and the Drivers for the HP Printer.
Dec 04, 2007 | D-Link DP 311U (DP-311U) Print Server
Printer offline
1) Ensure you've run the D-Link supplied automatic configuration wizard. 2) Also ensure you have "Netbios over TCP/IP" enabled in your network settings. 3)Ensure you turn off "Bidirectional Printing" in the Ports tab and "Enabled Advanced printing features" in the advanced tab, for testing purposes. I know the printer connectivity is officially supported by D-Link (thru an independent 3rd party test facility) but it seems they may have had NetBeui installed, which is an outdated networking protocol. Try the first 3 options I gave, if they don't work, then let me know. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
HP (J4107AABA) (J4107A#ABA) Print Server Logo
208 people viewed this question
Top HP Print Servers Experts
Martin Murray
Sudeep Chatterjee
Sudeep Chatterjee
Nalin DSouza
Nalin DSouza
Are you a HP Print Server Expert? Answer questions, earn points and help others
