Question about Zanussi FJS1225W Front Load Washer
Electronic lock up
E40 displayed will not allow machine to operate
  • 139 Answers
Error code is for door interlock...
However it is also possible that a track on your pcb that is connected through wires to the the door lock has will now need to replace the pcb aswell.this seems to be a common problem where doorlock blows pcb after failing
Posted on Jan 15, 2008
When I switch on my washing machine AEG Lavamat turbo 16800 it displays E40
HI Mike.
E40 relates to the door being left open when the programme is started, it maybe that the latch was not pushed over when the door was shut.
to solve the problem get another switch.
hope this helps you.
or read up some more at this link.
washing machine AEG Lavamat turbo 16800 it displays E40 Google Search
Dec 20, 2017 | AEG Washing Machines
Error code E40 on a Electrolux Front Loader Washing Machine EWF80743. What does it mean and how can I fix it?
E40 relates to door lock faulty or not closing - you probably need a new door lock, but check the catch on the door hasn't snapped off first. You will also get E40 if you try to start the machine with the door open.
Dec 01, 2017 | Electrolux Washing Machines
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
Jul 16, 2017 | Washing Machines
How to reset zanussi jetsystem programme function board with error E40
E40 is a door lock fault code, you need to replace the door lock,
you cannot reset the fault code, this happens automatically when the fault is rectified. nice easy job though.
Sep 30, 2016 | Zanussi Washing Machines
Electrolux EIFLW55HMB0, I start the washer and it makes a clunking noise like it's trying to lock the door and then it says paused. It was working fine, Then it started doing this. I was able to get it to...
Are you getting fault code E40? Certainly sounds like a door lock problem. Is the spring on the door catch strong enough to operate the door lock? sometime the plastic moulding that holds the door catch mechanism breaks if the door was forced open. Double check the connector on the new electronic door lock. If not his, may be electronic panel problem, or connections pulled of the board while you were fitting the new door lock.
Oct 23, 2017 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
Apr 09, 2009 | Electrolux Washing Machines
Zanussi zwf1430s error codes - E40 / E41 & ELE
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
Mar 19, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
197 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
