Home | RCA | D52W20 52 in. Rear Projection HDTV-Ready Tel... | No sound
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Problem for RCA D52W20 52 in. Rear Projection HDTV-Ready Television
No sound
By lateralus121 on Nov 09, 2009
I moved the t.v. from one room to another now i don't have sound
Solution #1
posted on Nov 13, 2009
Not Rated)
dtillis
Rank: Master
Rating: 90%, 2 votes
I agree with Tim931. RCAs and Magnavox 52 and 55 inch rear projection tvs have a speaker switch on the back of them. Flip the switch to on. My neighbor had the same issue with the same tv. Good luck.
Was this helpful?
Yes
No
Solution #2
posted on Nov 09, 2009
Not Rated)
tlm931
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 54 votes
one thing to check is to see if your model has a speaker swith on the rear panel and see that it didnt get bumped to off
other wise check speakers in the menu to see if there turned off
if not there then you will have to trouble shoot the small signal board
Was this helpful?
Yes
No
Popular Solutions for RCA D52W20 52 in. Rear
Questions and Unsolved Problems for RCA D52W20 52 in. Rear
Do you recommend RCA D52W20 52 in. Rear Projection HDTV-Ready Television?
Answer
Answer
How long to an unplugged complete idle discharge for an RCA D52W20 rear projection? many thanks
Answer
tv wont turn on the green light comes on for a second or two then goes off then comes back on and... (More)
Answer
i have arca hdtv rear perjection #d52w20 the power light keeps going out
Answer
i have an rsa 52'' hdtv. when i try to turn on ,the power light go's off
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA D52W20 52 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
