Question about Gateway 450ROG Notebook
Broken monitor wiring harness
Found two broken orange colored wires (side by side) on the left side hinge of a Gateway 450rog laptop. How can I make sure I wire them back together; same wire to same wire?
  • gee1 Jan 07, 2008
    iam gee1 take aclose look to make sure that there is not a light colored strip going down one of the wires if not reconnect them and you will be up and running gee1
  • mwag4 Jan 08, 2008
    Thank you gee1! Your suggestion worked and now I have the computer working again, just as you said.
    Michael
  • 89 Answers
MS 2285 screen is intrermittantly blank
Yes the screen data connection wires run past the left side hinge. Over time the wires, due to flexing wear through to some degree.
This data bus should be replaced as soon as possible. If a short occurs then it can damage the pc or the screen.
A pc technician will be able to fix it.
Take care!
damnor01
Jun 06, 2012 | Gateway Computers & Internet
Tip
Door locks or windows not working at times.
Alot of older cars and even some newwer cars and truck, you may find that door locks or windows work sometimes and not other times and they may not work at all. i've found that many of them are not working due to a broken wire or two in the wiring coming inside the door where the door hinges are located, in side the rubber boot, pull boot back from rear and front one at a time and take a good look at the wiring , make sure there are no broken wires, these wires sometimes break in half from the door opening and closing so many times, if you find a broken wire it can be repaired by adding a small peice and crimping them back together. this happens to alot of makes and models, like jeep, chrysler and gm,
on Sep 05, 2010 | Jeep Grand Cherokee Cars & Trucks
Broken swivel hinge on Gateway m280e laptop.
not sure about documentation - but for parts you might try dakotapcwarehouse.com - my company has found parts for a lot of its older gateway laptops there
Jun 03, 2010 | Gateway M280E
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Gateway 450ROG WiFi Not Working
Sounds like you need to look at that board closer. You wifi is not getting power.
Feb 21, 2009 | Gateway 450ROG Notebook
Gateway MT6705 Hinge
call gate way or check with best buy
Feb 06, 2009 | Gateway 450ROG Notebook
2000 toyota camry check engine light. trac light on. when i step on breaks reverse square indicator on dash board goes on. No reverse lights and rear light indicator on.
wires are pinched and shorting together near the left (drivers side) trunk hinge. brake light power is feeding back through the reverse light wiring. this will also turn on the check engine light with a neutral safety switch malfunction code as the computer also sees this voltage in the reverse light circuit. Find and repair the wiring, pull the EFI fuse in the panel under the hood to clear the code. Hope this helps
Dec 27, 2008 | 1999 Toyota Camry
Dark screen
Hello there:
It seems like ur hdd is not working propertly
or Ram
or VGA check those 3 and if they are ok WRITE HERE back.OK?
Nov 07, 2007 | Gateway 450ROG Notebook
Gateway 450ROG Notebook Logo
138 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
