washer stops in rince cycle, also drain pump stops and starts. does not drain completly. may be overheating pump motor. also looks like may be leaking at pump.
Washer processes through fill and agitate cycles. I can also hear it spinning. I do not believe it...
(More)
Washer processes through fill and agitate cycles. I can also hear it spinning. I do not believe it is producing rinse water through the rinse cycle. Warning "too many suds".
Water splashing between top cover and drum during wash cycle. Air gap between the drum and lid/deck...
(More)
Water splashing between top cover and drum during wash cycle. Air gap between the drum and lid/deck seems excessive. Lots of water running down the inside sides of the washer and thus the floor. I plan to test with a light load to check water level sensor and re-verify no pump, hose, and case leaks. Can't find water level sensor test with the diagnostic code system. New pump,diverter valve, power supply and agitator. Hate to pitch. Wife really likes this unit. Thanks for any help in this watery matter.
My Fisher& Paykel washer has a constant drip coming from the fill tube inside. Is there a...
(More)
My Fisher& Paykel washer has a constant drip coming from the fill tube inside. Is there a washer I can replace?
The following problem has started taking place every few washes but not every time. My Fisher Paykel...
(More)
The following problem has started taking place every few washes but not every time. My Fisher Paykel Ecosmart (about 7 years old) stops operating while the two wash lights are still on and beeps continuously. I open it and there is water up to and over the wash but the only way I can get it to complete the wash is to turn off power, turn it back on, advance it to rinse cycle and restart it. It does this even when the load is light.
