LG LS-K2430HL 23000 BTU Heat and Cool Mini Split Air Conditioner
Problem for LG LS-K2430HL 23000 BTU Heat and Cool Mini Split Air...
No more condense water outside, leaking heavy
By raybona on Nov 08, 2009
no more condense water outside, leaking heavy inside the room from the bottom of the handler
Solution #1
posted on Nov 09, 2009
Not Rated)
Therinnaiguy
Rank: Guru  Air Conditioners  Expert
Rating: 88%, 410 votes
Take a shop vac and **** the pipe out from the outside. You have a blockage in the condensate pipe.
Was this helpful?
Yes
No
Popular Solutions for LG LS-K2430HL 23000 BTU Heat
Questions and Unsolved Problems for LG LS-K2430HL 23000 BTU Heat
Do you recommend LG LS-K2430HL 23000 BTU Heat and Cool Mini Split Air Conditioner?
Answer
Answer
after turning on, the lg model ls q096bul, turn off after 1 minut. Stending by light kips blinping.
Answer
I have 4 johnson MN series ac units in my house, And find that 2 of them wont start from the remote,... (More)
Answer
Dear, I need 2-Ton Hot & Cool Split AC with automatic operation On & Off. or If we... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG LS-K2430HL 23000 BTU Heat...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
