I took the back off my Toshiba CE30C10 Television and used compressed air to blow out the inside. It wasn't working. Just click, click. Plugged it in and it seemed to fire back up, but I found that in my over zealous ''cleaning'' I blew a connection off. I can't seem to figure out where it goes. It appears to be a 3 pin connector that is coming from a white wire from a plastic adjustor slid over the bulb. Any ideas where it goes?
i am sorry that happened to you, but the best way is to get a schematic and find it. you could also just take your time and look for a socket that could accept this connection in your set. if you only have one loose connection then you look for the socket that does not have any dirt inside of it. it will be this way because it was plugged in and no dirt could get inside. blowing it out might have been the way you could have found your problem.
my samsung flat panel tv has a veiwing problem. it seems to be zoomed in so that the left and right...
(More)
my samsung flat panel tv has a veiwing problem. it seems to be zoomed in so that the left and right are not visible.
