Thanks for using FixYa.
Dishwasher not draining properly or not draining at all issues can arise due
to different reasons. Usually, these issues are related to kinked hoses,
knocked out disposer unit (if connected with the dishwasher drain hose) &
clogged drain pump & filter.
Also note that dishwashers do not
drain completely after a finished cycle and this is normal. Dishwashers are
designed to leave some water in the unit to ensure that the heating element
doesn’t overheat. If you suddenly begin to experience a large amount of water
being retained in your dishwasher, you have a problem. Some of the most common
reasons include that the drain hose isn’t working properly, the drain pump
isn’t working correctly, or possibly there is a plumbing problem in your home’s
drain lines.
First check whether the drain is
not clogged or blocked and the line is not kinked. Check all the hoses for
blockages & also clean the air gap. Has the disposer been replaced
recently? If so, chances are the knockout is still in place. Simply remove the
drain hose from the disposer, and knock out the plug. If the disposer has not
been replaced, try removing the drain hose from the disposer and use a wet-dry
vacuum (prepared for water, of course) to **** any water (and hopefully anything
else) from the drain line. Then reconnect the hose, and test the unit. If you
have checked the air gap and the drain hose and can’t locate the problem, then
it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further
assistance.
dishwasher is leaving white spots, won't clean. I there some kind of maintenance that will solve...
(More)
dishwasher is leaving white spots, won't clean. I there some kind of maintenance that will solve the problem?
I have a kenmore ultrawash, quietguard 4 dishwasher that is 3 years old and gets regular use. The...
(More)
I have a kenmore ultrawash, quietguard 4 dishwasher that is 3 years old and gets regular use. The problem is that it is not quiet anymore. About 2 weeks ago it began making a whirring noise that begins when you start and continues thru the end. It still cleans the dishes well but the noise is annoying. Maybe a motor bearing or something of that nature? I am handy so I am sure I could fix it if I could pinpoint the problem. Any suggestions would be helpful. Thanks WHMS
