Question about NEC PlasmaSync 42MP3 42 in. Television
NEC Plasma Sync 42MP3 Problem
Hallo. Sorry for my english ! !
My monitor NEC 42MP3 not power on. When i try to power it, standby led flips red and green alternatively. Thanks and good year.
Thanks, the 3 step procedure worked a treat!
Posted on May 05, 2008
This happened to me and I found a posting that fixed it (at least for me). Follow these steps:
  1. Power off the system.
  2. Press & hold the Input Select button.
  3. Power on the system while holding the Input Select button.
Posted on Mar 01, 2008
Hi, This model has some design flaws and yes NEC admitted to them a year ago. The problem with your monitor (hopefully) is a bad power supply. Have a Tech with a voltage tool check the boards as well as the connections Reason, this monitor generates a lot of heat ( no cooling fans) primarily at the power supply and sits there. So the wires tend to go weak by the heat build up. What the problem is the power is not going to the correct board in the right voltage. hope this helps out!!!
Posted on Jan 16, 2008
6ya staff
SOURCE:
Nec plasma sync 42mp3 doesnt have wall antenna connection point. simple coaxial connetion.
It does not have TV tuner, it is just a display for Video source, you will need Tuner box.
Read about it here:
http://www.plasmatvbuyingguide.com/plasmatv/nec-42mp3.html
Please leave rating if it helps.
Mar 06, 2011 | NEC Televison & Video
I have a Nec Plasma Sync 42vp4g/s Monitor. I have connected only a video RCA on VIDEO 2, but the monitor is turning to black ( the stand-by light is still green ). Sometimes it makes some flashing showing...
Your video input on VIDEO 2 via the RCA jack is most likely composite analog signal (good old
obsolete NTSC), and the Television may be in High-Def mode, therefore not looking for, and
not understanding anything but an HDTV (digital, ATSC) signal.
58-page users manual (language=english) for your television:
http://www.nec-display-solutions.com/p/download/pr/File/cp/Products/PublicDisplays/Supported/XGA-PX42XM2/ProductManuals/Manual-PX42XM2%28english%29-CD-ROM-Version.pdf?e=e1s1&fn=PX42XM2-UserManual-english.pdf
Jan 26, 2011 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Red LED lights
power supply shot ... sometimes x board or y board
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
NEC PX 42XM1A won't power on
Any chance you might think that it is your remote control faulty? As you need it to turn your plasma on from standby via remote (only). Let me know.
Apr 23, 2009 | Televison & Video
Ariel
Its NOT a TV, its a display. It does not have its own TV tuner or RF converter. You have to runit from a VCR, A DIgibox or SKY TV.
Jul 27, 2008 | NEC PlasmaSync 42MP3 42 in. Television
My tv urgent
Hi - first check that all the fans are rotating - the set will shut down if they are not.
***** WARNING potentially FATAL voltages (up to 400V DC) exist on the PSU boards - if you don't know exactly what you are doing don't ! *******
Unfortunatly the fault could be on a) PSU b) CPU board, as this monitors the PSU voltages and will shut down the set if the measured voltages are wrong c) plasma drive circuits - if these are drawing excessive current, or someother fault exists the fault feedback signal to the CPU board will activate and the set will again shut off.
Check the PSU voltages, the standby power must be OK otherwise the set wouldn't work at all !. The +5V switches on first followed by the +70V and +170V (about 1-2 secs delay.)
If the 70 and 170 dont come up try removing (with the power DISCONNECTED) the two large double row connectors on the PSU board near the 70/170 V test points - these supply the plasma drive circuits - the set will still switch off as there is a fault feedback line from the drivers, but it should stay on long enough to check the voltages.
Feb 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
NEC PLASMA SYNC 42MP2 STANDY BY MODE?
According to the manual for "POWER/STANDBY indicator is blinking in red":
  • "The temperature inside the main unit has become too high and has activated the protector."
  • "Promptly switch off the power of the main unit ans wait until the internal temperature drops."
  • "If the monitor becomes too hot, the overheat protector will be activated and the monitor will be turned off. If this happens, turn off the power to the monitor and unplug the power cord. If the room where the monitor is installed is particularly hot, move the monitor to a cooler location and wait for the monitor to cool for 60 minutes."
Feb 04, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Nec 42'' plasma
Try holding down the 'INPUT SELECT' button, then press the power button on, on the tv at the same time.
Oct 29, 2007 | NEC PlasmaSync 42MP3 42 in. Television
Blank Screen
Hi Gemma - have a look at this forum - it may be similar to what you are experiencing. http://forum.eserviceinfo.com/viewtopic.php?t=5411&postdays=0&postorder=asc&start=0 Things don't look good for NEC owners I must say! Good luck Saty.
Dec 28, 2006 | NEC PlasmaSync 42MP3 42 in. Television
NEC PlasmaSync 42MP3 42 in. Television Logo
409 people viewed this question
Top NEC Televison & Video Experts
Ekse
Kyle Steven OHare
Kyle Steven OHare
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
