Question about Electrolux EOB5600 Ultrafan Electric Single Oven
Electrolux EOB5600 electrical fault?
There was an electrical smell when the oven was in use, then the unit stopped working. I took the oven out of the housing to find that the neutral cable had burnt right through in the terminal on the back of the oven!  I'm not sure what to do with the oven as its not under guarantee (2 years old bought from new) or whether it is able to be repaired. The plastic terminal which secures the live,earth and neutral cables is black and cracked. I guess i'm lucky it didnt catch fire! Any ideas would be greatly received. thanks.
  • 2 more comments
  • middleton Jan 06, 2008
    Hi, thanks for your quick reply. Although i still cant understand why the heat of the oven would burn out the neutral cable and not the others, and also why the fuse didnt blow in the plug (doesnt appear to be one on the oven).
  • middleton Jan 08, 2008
    Would a 30 amp porcelain block be suitable? (as i cant find ceramic wire nuts anywhere) or even a high temp plastic strip connector? many thanks for your help.
  • middleton Jan 13, 2008
    Only just got round to the oven. Seems to be working fine altho i will test it when i get an amp meter. Many thanks for your help.
  • 640 Answers
Goto home depot,lowes and get some ceramic wire nuts and heat tape and electrical tape.cut the wires back on both sides of the terminal block.bypass the t-block and connect the wires with the wire nuts wrap the heat tape then electrical tape on each one.if you have access to a amp meter take readings to make sure the amp draw isnt too high.i would think the wires just burned up from either a loose connection or the heat of the oven.this should solve your problem.
Posted on Jan 06, 2008
  • anthony james
    anthony james Jan 06, 2008
    the terminal blocks are made of high temp plastic and just fail.its possible that the neutral line is drawing high amps but i doubt it.im a service tech for hobart and ive seen this quite often,just a weak t-block.when i encouter this issue i repair it just like i said.i dont replace the t-block.could you please rate,thank you
  • anthony james
    anthony james Jan 08, 2008
    if you have a porcelain block that should be fine.let me know how you make out.
Electrolux EOD5310 Electric Double Oven power to oven but no heat
If you have a problem with your Electrolux EOD5310 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2014 | Electrolux EOD5310 Electric Double Oven
EW30EW65SS Stainless Steel smells like burning electrical
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
Jan 31, 2013 | Electrolux EW30EW65SS Stainless Steel...
I have a brand new electric oven. When I switched it on there was a very strong smell of burning and when I opened the door alot of what appeared to be fumes came out, is this normal when an oven is new?
yes - there is a chemical put on the elements to keep them from corroding and appearing new until first used.
The smoke will go away after the first bake.
It is non-toxic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 13, 2009 | Electrolux EOB5600 Ultrafan Electric...
A bright light flashed in the oven and now it is not heating up what can be wrong the fan is still working though and the grill
Check the thermal fuses / sensors mounted on the top exterior of the heating chamber and also the heating element. Both accessible from the rear of the oven. The element is most likely to have gone. It will be a 2 or 3 turn coil type with the fan mounted to the middle of it. You will need to check the number of turns of the coiled element and also the mounting holes to ensure you get the right type. Turn off the mains power at the breaker or distribution point. You can get to the element behind the rear plate of the oven cavity by removing the side shelf slides, and rear panel by undoing the securing screws on the plate (2 or 4 depending on the exact model you have). Often a good idea to take a photo of the element mounting and take the model and serial no of the oven so that you can take this to the domestic appliance shop or email it to an online supplier to make sure that the element they supply is correct for your exact oven.
Nov 08, 2009 | Electrolux EOB5600 Ultrafan Electric...
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
HI, MY ELECTROLUX SINGLE FAN OVEN EBO5665 DOES NOT HEAT UP TO ANY TEMP. THE OVEN IS ON, FAN ON,AND THE TIMER DIALS ARE SET. DOESNT HEAT UP. IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME. ANY SUGGESTIONS!...
You probably have a bad ( or open ) heating element.. With the power removed.. look at the heating element and make sure it is connected properly and if after you check that it looks ok.. plug it in and try again.. if it fails to get hot..its probably bad.. Not sure what you mean when you say ' IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME' but if it tripped the switch or circuit breaker .. your heating element may be shorting out to ground.. and would need to be replaced anyway... Hope that helps.
Aug 22, 2008 | Electrolux EOB5600 Ultrafan Electric...
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Oven not working
is this a gas oven or electric?
Oct 24, 2006 | Electrolux EOD5310 Electric Double Oven
Electrolux EOB5600 Ultrafan Electric Single Oven Logo
319 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
