smelly top loader. It stinks. The clothes don't smell, though. The smell is coming from between the porcelain bowl and the metal exterior. It realy smells terrible. I've run 2 loads of hot water with bleach through and wiped down the interior ring of the bowl, and nothing helps. How do I get between the porcelain bowl and the metal washer?
Bacteriological action is becoming more of a problem nowadays due to low temperature washing , the deteregents , wash your clothes well but do not kill off bacteria , this is generally harmless to us but can build up in your machine , giving rise to a smell and sometimes a slime which can get on your washing. A regime of High temperature washes WITH NO CLOTHES IN MACHINE , just a dose of bio-powder every six to eight weeks , may help.
Splendide wash/dry combo: the unit washes just fine but then the dryer does not heat. The vent pipe...
(More)
Splendide wash/dry combo: the unit washes just fine but then the dryer does not heat. The vent pipe is clean and the pump has been cleaned.
pump block message. drained with wet-vac, pump impeller is spinning. worked through soak/drain...
(More)
pump block message. drained with wet-vac, pump impeller is spinning. worked through soak/drain cycle. in wash cycle it worked until rinse cycle (when it fills with more water) then it stopped and message displayed. checked hoses, pump motor sounds like it is running with no water flow before message is displayed.
