My two drawer dishwasher keeps turning itself on. No water is running. It sounds like it is trying to drain. I've checked the filters and they are clear. Everytime I stop it, it starts up in about 10 seconds.
There is a leak in the unit. What you'll have to do is to take the bottom drawer out of the casing and you'll find water in it's casing. The computer in the unit is detecting a leak and is trying to empty. Take the bottom drawer out by pulling the drawer out gently and disengage it from the side rods just like you would when you take out your drawers in your refridgerator. When you are able to lift the unit out (you may want someone to help because it can be heavy) you will see the tubes attach but look in the casing that holds the entire unit and you'll probably see some water. You'll have to dry the water out before putting the drawer back. If this still occurs then that means the computer board needs to be replaced because it's probably damaged from the water leakage.
leaking water, drawer lid on lower unit not sealing.DD603 I had an item that was to tall for drawer....
(More)
leaking water, drawer lid on lower unit not sealing.DD603 I had an item that was to tall for drawer. is there a way to check and re-align the lid assembly
