Uniden Cordless Phone
Problem for Uniden Cordless Phone
Change voice mail message
By bolduc_willi on Nov 08, 2009
change voice mail message from one person to another person
Solution #1
posted on Nov 08, 2009
Not Rated)
sangitha_ss8
Rank: Wiz
Rating: 81%, 156 votes
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Service (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • Was this helpful?
    Yes
    No
    Popular Solutions for Uniden Cordless Phone
    Questions and Unsolved Problems for Uniden Cordless Phone
    Do you recommend Uniden Cordless Phone?
    Answer
    Answer
    preset pin for remote message retrieval
    Answer
    Who represent uniden in India
    Answer
    unable to erase stored numbers I have tried to followthe book, on the information related to using... (More)
    Answer
    phone wont connect. when i try taking out the battery and then reinserting it it states the phone is... (More)
    Answer
    Phone does not ring goes immediately in to message. I have reset it several times to wait till 6... (More)
    Describe your problem:
    Select a Category:
    Ask our Experts
    Solve Your Problem Now!
    Chat Live with an Expert
    Chat Now
    Browse popular Problems
    More Common Problems
    Most Common Problems for:
    For Uniden Cordless Phone:
    Top Phone Experts
    Rank: Guru Guru
    Solutions: 563
    Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
    Ask Me
    Find more Phone Experts
    Top Telephone Repair
    (800) 513-9962
    Component level repair and complete refurbishing...
    BARCLAYENTERPRISESINC
    (316) 262-7171
    Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
    Chat Now
    X
    Continue
    When the original poster rates a solution that was given to his own problem, that rating is locked!
    X
    Are you sure the solution content is Inappropriate?
    Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
    Insert Link
    Insert Image
    Insert You-Tube clip
    Insert List
    Insert List
    Spell Check
    What is this?
    Select
