Home | Frigidaire | (ATF6000ES) Front Load Washer | FAULT CODE E-20 ON FRI...
Frigidaire Front Load Washer
Problem for Frigidaire (ATF6000ES) Front Load Washer
FAULT CODE E-20 ON FRIGIDAIRE AFFINITY FT LOADER STOPS BEFORE SPI
By mcalive on Nov 08, 2009
STOPS BEFORE SPIN CYCLE LEVING WATER IN MACHINE, I CAN PUT IT ON SPIN OPEN THE DOOR AND TURN THE TUBE AND RUN IT. THERE IS NO PROBLEM WITH MY HOUSE DRAIN.
Popular Solutions for Frigidaire Front Load Washer
Questions and Unsolved Problems for Frigidaire Front Load Washer
Do you recommend Frigidaire (ATF6000ES) Front Load Washer?
Answer
Answer
I have a Frigidaire Gallery front loader washing machine that the tub has stopped rotating on. water... (More)
Answer
how does the timer come out of a 2000 front loading frigidaire washer
Answer
black rubber in front seal of door seems jammed what do we do
Answer
It goes through part of the cycle but stops before spinning and code A20 comes up. I don't have the... (More)
Answer
model gltf1040ASO the motor will spin for the back and forth cycle but not the spin cycle...makes a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14747
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
