Question about Panasonic CT-32SL14 32" TV
CT-36D30B Two problems, first the TV shuts down by itsself, if you bang on the back, it will make a click sound and come back on in a few minutes. Also the vertical goes out and theres just a line down the center of the screen. If they are cold solder joints, how can i find them.
  • 74 Answers
If you know how to solder is a pice of cake,,,, but be carfull the tv store a high voltage in the picture tube and beliveme is a very dangerous one but if you decide to go on the vertical Ic is the one with 10 or more conection pin (in some model 7or 8) and is atach to a heat sinc (a pice of metal) to cool down the Ic solder all the pin and check to dont joint to pins with the solder dont applay to much heat or will spoil the IC allso check the power suply area for cold solther to thepower suply is the area were the ac cord is atach all around there....remember dont touch repeat DONT TOUCH the heavy red cable coneted to the picture tube and as techman say get some buddy beside you with a telephone redy to call 911......good luck and rate me
Posted on Jan 06, 2008
I have a 2001, Panasonic 27
Suspect either bad solder connections somewhere or a issue in the power supply of the set----set will shut down for a number of reasons--it monitors voltages inside and if some go high or low it will shut down.
May 16, 2012 | Televison & Video
Panasonic TV picture shrinks to a line
There is an IC which controls the vertical deflection and over the course of a few (or 8) years with the set heating up and cooling off some of the connections work their way loose causing the symptoms you describe.
If you were to bang on the side of the set you could likely "pop" it back in but this is not a good solution. The vertical IC needs to be re-soldered. This is especially common in Panasonic sets. About 10 minutes with a soldering iron should have it worked out.
If you're handy with a soldering iron I can tell you what to look for.
Oct 09, 2008 | Panasonic CT-32G14 32" TV
My panasonic tau ct-34wx52 tv shut off by itself, now only clicks
Its power supply regulator section circuits need to to be troubleshooted.
Apr 26, 2012 | Televison & Video
Black picture
there is a loose connection in you PCB , shut off the tv unplug it, then open the back cover remove the PCB. turn it upside down. Resolder the semiconductor leads. all
Jun 22, 2009 | Panasonic CT-35G25 TV
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
Panasonic CT-27G34A screen jiggles/glitches up and down slightly
Sounds like dried up cap either in vertical circuit or power supply.
Apr 27, 2008 | Panasonic CT-27G34 27" TV
Receiver shuts down after loud bang
You said Unit is enclosed!! Does that mean it is inside something? Receivers & Amps need to have a clearance above them so air can circulate, otherwise you'll have an overheating problem. You also might have some of your wires crossed which will cause the Amp to shut down. Look at all your connections and make sure they're correct, including speaker wires.
Sep 22, 2007 | Audio Players & Recorders
My Panasonic TV
Many TVs, including some Panasonic models, have an Auto-OFF feature that will automatically turn the set off after a few minutes, if the TV thinks it is not receiving a video signal. By reinserting the coaxial cable, you are probably restarting the Auto-OFF timer inside the TV. There are several possible things that could cause the Auto-OFF to falsely activate. Try and change the coax cable going from the VCR to the TV, if you have a spare. If not, plug the cable from the cable box directly into the back of the TV. Make sure the TV is on the correct channel, usually Ch 3 or Ch 4. (Do not use the original cable that was running from the VCR to the TV, just in case it is intermittent.)
Sep 07, 2007 | Panasonic CT-36D32 36" TV
TV keeps shutting off and then on on its own
u have a bad solder inside your tv or most of the time called "cold solder". if u have soldering tools, inspect the board inside for possible cold solder and resolder it.
Jan 15, 2007 | Panasonic CT-27G33 27" TV
Panasonic CT-32SL14 32" TV Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
