- You have to select which model of the comcast remote you have, then down load the manual of that remote, it will contain the codes, if it is not listed, then you can also run the 'search for your coed function'
Nov 09, 2009
- Example: from the one of the remote manual
SEARCHING FOR YOUR CODE
If your home entertainment device does
not respond to the remote control after
trying all of the codes listed for your
brand, or if your brand is not listed at all,
try searching for your code.
For example, after trying all of the codes
for your TV, you still cannot get the
remote control to operate your TV, then:
1. Turn on your TV.
2. On the remote control, press TV
once.Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1.The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off.A
working code has been found.
NOTE: In the search mode, the remote
control will send IR codes from its
library to the selected device, starting
with the most popular code first.
5. Press Setup once to lock in the
code.The TV key will blink twice.
6. To search for the codes of another
device, repeat steps 1 to 5, but substitute
the AUX key for the auxiliary
device you are searching for.
