Question about GE Profile Harmony DPGT750EC Electric Dryer
GE Profile power cord
My power cord has 4 colors black, red,green and white. how do it connect them?
  • 290 Answers
White is the neutral circuit and it goes to the center connection of the terminal block on the dryer. Red and Black are "hot" wires and they go to the connectors on the ends of the block, doesn't matter which color is on which side. Green is the ground and it goes to the cabinet ground.
Post back if you have any questions.
Posted on Jan 06, 2008
  • Michael  Lindley
    Michael Lindley Jan 07, 2008
    Just wanted to follow up and see if you got dryer wired up.
Switching 3 prong cord to a 4 prong cord
if theres a wire from the center terminal on the dryer terminal board going to the dryer case disconnect it,then Red & Black on the cord go to the outer 2 terminals on the dryer terminal board,the White goes to the terminal in the center between where you put the Red & Black wires this is the Neutral wire,then the Green wire connects to any metallic portion on the dryer case as this is the SAFETY Ground wire and also Red & Black can go on either outer terminal on the dryer terminal board as these are not polarity sensitive because its A.C. power so wire it on the dryer terminal board as in (RED-WHITE-BLACK) on the dryer terminal strip and connect the GREEN to any Metallic portion of the dryer case
Dec 30, 2012 | GE Profile Harmony DPGT750EC Electric...
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
4 prong cords
Either way, plug or dryer cord the white wire goes with the green wire, they are pretty much the same. On the dryer at the block where you are connecting the cord, look just above it and you'll see wires coming into it, the red and black are on the outside, I'm not sure which color on which side but the white and green go in the middle on top one another and the red and black match respectively.
May 17, 2012 | GE DBXR463EBWW Electric Dryer
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
Power cord replacement (3 prong to 4 prong)
Your new cord has 4 wires. Black, red, white , green.
The dryer has 3 lugs to connect to. Connect the white and green to the center lug, connect the red to left lug and the black to the right lug. You are all set to use dryer.
Jun 06, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
AEM407WZ Electric Dryer - 4-wire cord installation
red and black are the 2 power phase wires and go on L1 and L2 terminals or on an inline power block the 2 outer terminals(polarity)doesn't matter,then white is the center or N-neutral terminal, then green or green/yellow stripe is chassis safety ground and is connected to the metal frame of the unit
Mar 04, 2010 | Dryers
The power cord on my Whirlpool washing machine is not connected. There are 4 cables (red, black, white, and green). I can see where the black, white, and red, but where does the green one go? There is...
The following link explains how to correctly install a power cord on your dryer:
The main difference between the 3-wire and 4-wire configuration is how the Neutral (WHITE) wire and Ground (GREEN or BARE COPPER) wire are terminated on the terminal block in the back of the dryer:
- In a 4-wire configuration, these two wires are INDEPENDENT of each other and are terminated separately.
Terminate the wires at the terminal block by matching the corresponding colors:
WHITE to WHITE (Neutral) 0VAC
GREEN (Ground) - attached to a ground lug that grounds it to the equipment cabinet.
If you have any questions, please let me know. I hope this helps you
Dec 24, 2009 | Washing Machines
Need to change the cord on my Maytag MDE6000AYW from 3 prong to 4 prong. The (4) prong cable has black, white, green, red cables. Which colored cable connects to which terminal inside the dryer?
BLACK and RED are 110-120VAC each. WHITE is NEUTRAL - does not carry power. GREEN is GROUND. The Black, Red, and White Wires should connect to the terminal block & should correspond the colored wires already connected to the block from the machine. The Green wire should be grounded to the equipment chassis. I hope this answers your question.
Jul 13, 2008 | Maytag Dryers
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
GE Profile Harmony DPGT750EC Electric Dryer Logo
65 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
