YOU NEED TO BUY CORRECT SIZE NEW OIL DRAIN PLUG. YOU TO KNOW YOUR THREAD SIZE ON NEW OIL DRAIN BECAUSE YOU NEED THE RIGHT TAP AND DRILL BIT TO CENTER DRILL THE BROKE BOLT IN SIDE OIL PAN YOU NEED A CENTER PUNCH TO PUNCH A SMALL ENOUGH TO START THE DRILL BIT DEAD CENTER OF BROKE BOLT.OIL PAN NEED TO BE REMOVED TO DRILL HOLE STRAIGHT.THIS IN NOT A EASY JOB.EITHER YOU REPAIR OR DAMAGED OIL PAN DRAIN PLUG HOLE. YOU DRILL BIT HAS TO STRAIGHT WHILE DRILLING HOLE DEAD CENTER OF BROKEN BOLT YOU NEED TO MEASURE LENGHT OF OIL DRAIN PLUG BOLT. THEN USE A PIECE TAPE ON DRILL BIT WRAP A PIECE TAPE AROUND DRILL BIT THE DEPT YOU NEED TO DRILL THROUGH BOLT. LIKE I SAY THIS JOB TAKE SKILL AND A STRAIGHT HAND. BECAREFUL WITH DRILL AND WEAR SAFETY GOGGLES. DONT DO THIS FIX IF YOU NOT SURE OF MECHANIC SKILLS YOU WILL EITHER DAMAGE THE OIL PAN OR FIX THE PROBLEM.
NOPE DONT HAVE TO DROP OIL PAN.THE OIL PAN BOLTS CAN BE LOOSENED AND PAN DROPPED SLIGHTLY FOR THE FRONT COVER CLEARANCE.IF OIL PAN GASKET LOOK SWOLLEN CRACKED OR BROKE OIL PAN HAS TO BE REMOVED.
buy a tube of sealer called Right Stuff
1. Remove the flexible exhaust pipe
2. Disconnect the downstream catalyst monitor sendor (OXYGEN SENSOR)
3. Drain engine oil
4. Remove the 15 bolts and the oil pan
5. Clean pan & surface area.
6. Apply sealer 10mm (0.40 inch) diameter of sealer
7. Position oil pan and hand-tighten the oil pan bolts
8. Start with front of oil pan tighten each bolts going around oil pan till all are tighten up.
9. Install exhaust flexible exhaust pipe
10. Connect OXYGEN SENSOR connector
11. Lower the vehicle.
12. Fill oil 5w20 (Spec)
The oil pan was broken. They are made out of aluminum or cast iron. but i think it's hard aluminum. You are going to have it replace it. Don't drive the car without oil.Anyone can do it . Lift the car and secure it so it won't fall. Then remove that plastic thing you mentioned and remove the bolts around the pan . It has several . Be sure to buy a pan and gasket along with the pan.And replace.
1. Open the hood and access the relay panel on the Right side of the engine bay
2. Open the fuel cap
3. Start the engine
4. Pull the relay for the fuel pump (listed on the bottom side of the relay panel lid)
5. Wait for engine to stop
6. Turn key off
7. Disconnect negative battery cable
8. **** wheels to car
9. Slide under the driver's side around the B pillar area
9. Look on the interior side of the frame rail and you will find the filter assembly
10. Place a drain pan under filter
11. Disconnect the rigid fuel line with a 14mm opne wrench (I think)
12. Disconnect the quick coupling on the aft part of the assembly buy lifting up on the red plastic pience and turning
13. Unbolt the center bolt and pull out the filter
14. Pop in the new filter and reverse order.
