Question about Soltek SL-K8AN2E (SL-K8AN2E-GR) Motherboard
Continous Beeping sound
There is a continuous beeping sound whenever I turn on the power. Initially, I thought it was the PSU. But with the PSU not connected to the motherboard, there isn't any beeping sound. Once I attach the PSU to the motherboard and turn on the power, there is a beeping sound.
  • 7 more comments
  • neosw Jan 06, 2008
    Thanks for the prompt reply.
    Yes, this is a working computer for a few years. Did not notice when the beeping sound surface.
    Beside the irritating beeping sound, the computer is still working fine. I am still using it daily without any problem.
    Just trying to get rid of the beeping sound. I notice that the beeping sound is there even before I boot up the computer. It start beeping once I turn on the power switch on the mains with the computer in standby (off) mode.
  • neosw Jan 07, 2008
    This computer is still working fine except for the irritating beeping sound.
    How do I verify that the sound is coming frm the motherboard or the PSU? When I disconnect the PSU to the motherboard and turn on the power to the PSU, there isn't any beeping sound. Once I attach the PSU to the motherboard, turn on the power to the PSU but not power up the CPU. The beeping sound is there. Is this conclusive enough that the beeping sound is from the motherboard?
  • lptrevino1 Sep 25, 2008
    My computer started beeping constantly recently. It stops periodically for a few minutes before starting up again. It starts up normally and runs, although a bit slower. It freezes up occassionally now when it used to not do this. So far, today, it hasn't beeped yet at all, but it beeped all day yesterday. I replaced the power cord, checked and saw the power source (internal is adequate for what I have attached to it. Changed the internal battery. Reset the BIOS and clock.Cleaned the RAM and re-seated them, compressed air cleaned out everything. Disconnected the external drives and powered up each hardware item individually to see if it was a hardware anomoly. Did same with the new RAM cards ( 1GB card each, two cards).Used a new higher juels powerstrip, restored to factory TWICE after system restore to good point didn't resolve the issue. And no results. Even went thru the router to see if the router was the problem. I know my actual internet speed is a lot slower than what I should be getting. Checked and cleaned both the chassis fan and CPU fan. Is there anything else I should check? And can a diagnostic locate this issue, or will I be wasting my money on that? The computer is a SOny VAIO VGC-RB52 running Windows XP Pro, I added a PCi card with 7 slot USB/firewire ports, originally HD was replaced with Seagate 500GB old 250GB drive is now the slave drive.Have 1TB external Smsung drive in a Roseville enclsure with fan,second external is a reformatted Maxtor 500GB, have airlink router, SBC DSL modem,HP scanner/fax/printer,TiVo transfer device, Dazzle transfer device, upgraded RAM to 2-1GB 4200 DDR2 RAM.Any other info, please ask. Appreciate any help!!!
  • mankono Oct 19, 2008
    each time i turn my pc on the beep song came on and the pc does not work i have to turn on and off until it work.I do not no what's the problem.
  • Anonymous Nov 25, 2008
    My computer is a Dell Demasion XPS 400.
    My USB ports don't work, and thats when a beeping sound started, four seprate beeps of 4 beeps.
    monitor will not work and nor other connection.
    i opened the computer unpluged every connection to the motherboard. Removed the CPU, Look at the motherboard if it was fried or somthing but it seemed it was ok.
    fans work, hard drive works properly,
  • babydollred8 Jan 17, 2009
    I have a hp a1203w tower its beepin as soon as i turn on the tower main supply the screen stays on standby and will not turn on it was purchased as a gift, its 4 years old approximately. everything is hooked up as far as i know, what the heck is wrong with this thing? Please help doing my job from home......
  • Anonymous Mar 10, 2009
    the monitor working properly but there is a continous beep sound
  • joshlu134 Apr 25, 2009
    i got a lenovo windows vista vasic 3000 Q series intel core duo.....i on my computer then theres the beeping sound beeping 4 times stopping for a second and beeping twice more then beeping thrice two times
  • lptrevino1 May 11, 2010
    The beeping is coming from my chassis, not speakers, by the way. Thaks again!
  • 47 Answers
Hi neosw,
Could you provide a little more detail?
Was this a previously working set-up or is this a new build?
If this was a previously working set-up have you changed anything?
When you switch on the PC
  • do you see anything on the screen, does the monitor remain in standby?
  • are any of the fans running?
  • does the hard drive spin up?
  • does the beeping sound stop after a short while?
The reason I ask these questions is because a continues beeping usually means that the BIOS is not seeing the processor, or that the power to the processor is not correct. With some BIOS manufactures it can also mean the processor clock speed is not set
Please don't take this the wrong way but...if you provide greater detail in your question, the easier it for us to diagnose your problem, otherwise we can only make educated guesses.
I hope this has been of some help.
Spare head 2
Posted on Jan 06, 2008
  • Paul Griffith
    Paul Griffith Jan 06, 2008
    Hi neosw,
    Are you certain the sound is coming from the motherboard, even when the pc is not running?
    If it is then it may be that the power supply is leaking power the motherboard. Without power the PC speaker cannot make any sounds. That is a odd one...because you say it's present even when the PC is running, this is very confusing. Please try to verify the sound is actually coming from the motherboard and not the power supply.
    Spare head 2.
  • Paul Griffith
    Paul Griffith Jan 17, 2008
    Hi newosw,
    If you can, open the PC check to see the PC speaker is connected to the
    motherboard. If it is try disconnecting it, but make a note of how it
    connect to the PC. If you listen very carefully to the PSU at the back
    of the PC do you still here anything with the speaker unplugged and the
    PC switched off?
    If the noise is coming from the power supply this may indicate an impending failure.
    Spare head 2
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
A continous beep sound is hear in my ups..........wat shall i do now
Continuous beeping can be an indication that the battery needs replacing, especially if you have had this UPS for awhile
Feb 22, 2013 | APC Back-UPS ES 350 - UPS ( external ) -...
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
Not sure if it is MB or CPU when i try to turn on computer the only thing that happens is i hear a beeping sound. beep...beep...beep... continually. it wont go to the post, nada. the fans run and i have...
Continous beeps usually mean the motherboard or the power supply, Try another power supply first and see if it will boot, if not the motherboard is faulty, if the prossesor was faulty you would no beeps the fans would run but nothing on the screen. hope this helps.
Aug 24, 2010 | Computers & Internet
Continues beeping
did you leave it plugged in to let it charge? ups's will beep continuosly till they are charged, if it has dead battery packs inside, it will continue to beep because there is no battery charge to support its job. leave it plugged in for 2 hours. if it doesnot stop beeping, toss it and get a new ups
Jun 04, 2010 | CyberPower 575SL (CPS575SL) UPS System
My dell GX 1 optiplex pc is not powerring and power supply is not
If you don't have the LED lit up on the board, the most likely failure is your power supply. You should be able to get a computer store to test it, to be sure, but a replacement is $30-40
Nov 24, 2009 | Office Equipment & Supplies
Got my D845WN mobo going again, however it didn't last. Now when I switch it on the psu fan twitches but doesn't go. Nothing else starts. If I disconnect the 12V supply connector for the processor the psu...
try replacing youre power supply, or if youany spare one use if the result is still the same then you have a motherboard problem, i also have the same problem with mobo, same thing, i already tried using a diff power but there still no boot or any beeping sound,
Nov 23, 2009 | Intel D845WN (KD845WNPAK10) Motherboard
No picture and desktop makes beeping sound
Base on the post codes this continuous beeping indicates a power problem. Atypically this is a power supply problem and it will need to be replaced.
Oct 06, 2009 | Computers & Internet
Soltek SL-K8AN2E (SL-K8AN2E-GR) Motherboard Logo
971 people viewed this question
Top Soltek Computers & Internet Experts
John Anderson
John Anderson
Steven Wander
Steven Wander
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
