Maytag Neptune MDG5500AW Gas Dryer
Problem for Maytag Neptune MDG5500AW Gas Dryer
Matag Gas Dryer not heating up
By falcon9147 on Nov 08, 2009
Dear Expert:
My name is Gregg & I am a 20+ year Hydraulic & Mechanical Aircraft Mechanic for a large airline. I can fix most things, however this is one I don’t want to proceed without some who really know how to trouble shoot & find the best solution. Enough about me, here are my questions.
1. We have a 9 year old Maytag gas dryer Model # MDG4000BWW and it has stopped providing heat for drying our clothes.
• We had had a similar experience with previous gas dryer & I am thinking that our current problem might be of the same ilk.
• Here is what I understand at this point.
o Lint trap is clean, damp clothes are placed in the drum, the door is closed, temperature setting is dialed in at high heat, & the start button is engaged, everything begins to work like normal.
o 60 minutes later the clothes are wet & the drum cavity is cold.
o I physically checked to assure that gas was getting to the gas valve unit located at the bottom rear of the unit.
o I understand the gas valve has safety features built in so as to prevent ignition before all the right conditions are met for correct ignition.
o This is where I need help. Do I just replace the whole unit or can more diagnostics be done to correct the problem & if so, at what cost?
Thank you & I look forward to hearing from you very soon.
Gregg L. Mitchell
73 Maple Ave.
Atherton, CA 94027
(650) 380-2113
Best Solution
posted on Nov 08, 2009
Very Helpful)
jumptrout51
Rank: Guru  Maytag Washers & Dryers  Expert
Rating: 90%, 1077 votes
Check the glowbar igniter at the gas valve. When calling for heat(turned on and running) it should register 3 amps or more on a clamp on amp meter. If 120 volts of power is going to the glowbar and it does not glow,it is bad. All thermostats and relays should be checked for continuity. If any read 0 it is a bad part.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Maytag Neptune MDG5500AW Gas
Questions and Unsolved Problems for Maytag Neptune MDG5500AW Gas
Do you recommend Maytag Neptune MDG5500AW Gas Dryer?
Answer
Answer
Gas Dryer does not heat on any cycle - gas valve is turned on. Followed user manual suggestion to... (More)
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
