Question about Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD61 My washing machine does not spin and rinse the water out properly
  • mullygm Jun 15, 2008
    Hi, i have a Hotpoint WD61, which seems to wash ok but will not rinse or spin. I had a similar problem a few years ago when it was in warranty. They replaced the brushes and it worked ok until now. Could anyone tell how to check if pump is blocked and how to replace the brushes.
    Mully
    Problem Solver:
  • 5 Answers
1, your pump may be blocked by fluff coins and other debris.
2. more likely bushes worn on the main motor not giving enough umphhh (loverly word) to go through a complete spin....Bushes easily replacable. Job start to finish with parts on hand a machine mechanic 10-15mins top Diy er like me an hour allways have trouble finding the right spanner... Good luck.
Posted on Jan 06, 2008
  • 157 Answers
Pump check filter.,,on that machine big black sump hose go in through back
Posted on Nov 15, 2011
My hotpoint aquarius will not spin
If the inlet cycle proceeds and then activated the wash after the water level is detected then the program cycle is intact. However if the second spin does not start, you need to check if there is voltage to the motor at this time , if not the control panel memory to the processor can be corrupt or the IC damaged.
Jul 03, 2012 | Hotpoint WML520 Washing Machine
My WMS38 Hotpoint washing machine has the wash, rinse and spin and final spin lights on but nothing happens when the start button is pressed
Assuming tap water is turned on. If there is no water intake, the machine will not start. Check for the sound of water pouring in the machine. Check the water inlet filter, if it is jammed with foreign materials such as rust deposits, small stones, soil etc. Then check for the proper functioning of inlet water solenoid valve. Sometimes the valve gets stuck.
Nov 25, 2011 | Hotpoint Washing Machines
Hotpoint WD61 - I have taken back off, emptied blocked filter but having reasssembled the water does not drain and therefore does not spin. If I empty water via a bucket from drain hose the machine does...
hello, is sound like the pump not energizing the pump needs testing with a multimeter. fill it up again then empty it you should hear the pump kick in also check the hoses make sure there not kinked good luck
regards
shaun
Dec 05, 2010 | Washing Machines
How do i drain the hotpoint wd61 after a spin as it is full of water an dosnt seem to be doing it its self like it should any ideas please
Remove the drain hose, and lay it down into a bucket or bowl, the water will syphon out.
Check pump filter, located inside large black hose at rear of washer.
Please rate my solution.
Thanks.
Sep 15, 2009 | Washing Machines
Hotpoint Aquarius Model WD61 Washer Dryer working but it's noisey
If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine)
Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner).
If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
Update me about your progress
Good Luck
May 19, 2009 | Hotpoint Aquarius WD63 Front Load...
Working but making noise when spinning.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion....
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD62 Front Load Washer / Dryer Logo
576 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
