Question about HP Pavilion zv6005us Notebook
When I turn it on, there are blue lines that run down the LCD
HP ZV5000 notebook. When I turn it on, there are blue lines that run down the LCD. Even does it when I hook up to an alternate monitor. Anyone HELP!
  • JAY G Jan 06, 2008
    You mean the connection on my LED screen? Then would that explain it happening when I have a alternate screen plugged in?
    And thanks for any info!
  • ej_57 Feb 11, 2009
    I have a HP pavilion zv5000
    stripes run up and down the monitor and at times has garbled image.
    the same symptom when I attach a CRT. Any Ideas?
    Thanks
There is a loose connection on the screen you need o call in an repair man.
Posted on Jan 06, 2008
I have a HP Compaq 6910p with blue lines down screen ? can you help ? Please ; )
Hello there
I had this issue too with a Vaio i had. This means that there is a faulty connection between the ribbonconnecting your LCD monitor to the motherboard. Now, you can attempt to disassemble the PC and check the connection, but this would void your warranty and if you havent done something like this before, then i dont recommend it. What you should do is take it into your local service location to get this fixed.
I hope this helps. Thumbs up always appreciated.
May 06, 2011 | HP Compaq 6910p (GU888US) PC Notebook
Bought 1G ram from local computer store. It runs for about 5 minutes then i get a blue screen error and reboot. returned to store for a different mem stick...same issue. went to Crucial, found the...
Did you remove the "old" RAM, or did you add the "new" RAM to the old RAM?
Try using your computer with ONLY the "new" RAM installed.
Try using your computer with ONLY the "old" RAM installed.
Try using your computer with the "new" RAM in the 1st slot, and the "old" RAM in the 2nd slot.
Try using your computer with the "old" RAM in the 1st slot, and the "new" RAM in the 2nd slot.
Aug 27, 2010 | HP Pavilion ZV5220US (PF143UA) PC Notebook
When you turn on the laptop the screen is almost white with very small fine black lines going up and down. but hook up a external monitor and the lcd comes to life. Please help!!!!!
If it shows fine with an external monitor, then you would have to check your screen cable or screen itself. You would need a working one to test it with.
All the best.
Jan 19, 2010 | HP Pavilion dv9000z Notebook
Hi, I was using my HP Pavilion notebook with Vista when it froze. The cursor wouldn't move and I was unable to do anything. I tried contol/alt/delete to shut it down, but that didn't work. I then held the...
you could have accidently changed to external monitor with Fn +F(the number is 8 on my comp but could be 5 on yours-check keys on top of the keyboard it has a picture rectangle / little TV), anyways to check that attach external monitor to your laptop(must have a VGA cable) if you have a picture on external monitor try Fn + F(depends on what you have on ur keyboard) it should bring you a window with choices to choose laptop LCD or external LCD choose 1st one .
hope that is it.
Dec 28, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion notebook's screen is too dark to see!
do u have a external monitor,connect it up and see whether,u r output is any better..
Jul 22, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
PowerBook G4 15" Alumium LCD Cracked, see lines, HELP!!!
the new LCD is not match to your notebook. i'm sure not same all pin outs and pin in. its not compatible to the circuit board of notebook. even the LCD connector is also not compatible.
May 30, 2009 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
Blue thin vertical line on my monitor.
LCD needs to be replaced.
Common problem called "Tab separation".
Mar 22, 2009 | HP Compaq Presario R4000 Notebook
Blue and yellow lines on the screen
It's either the video card or the lcd. Try hooking the computer to an external monitor. If you get the same results on the external then it's probably the video card. If not, signs point to the lcd.
Let me know if you need any more help or info.
Feb 25, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion Laptop zv5000 wont power on. NOT power cord problem.
I think your motherboard has gone bad, even though you hear a fan working, its just on a hot wire on the motherboard.
Dec 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Blank screen
I think your LCD is stuffed is it under warranty do you know BUT if the screen is cracked they wont replace it typical HP. To get your external monitor running hold down the function key and the blue monitor looking key similtaneously normally on compaq its the F4 key but look around your keyboard (looks like a monitor) and is blue letters.
Sep 18, 2007 | HP Compaq Presario V2000 Notebook
HP Pavilion zv6005us Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
