You have a problem with tray movement in the finisher/sorter area. Sometimes those trays get slightly bnt if somebody leans on them and they dont strike the sensor in the center properly. If not then maybe the upper and lower limit sensors need to be cleaned or replaced
The F2-02 code will often be the result of a defective or after market toner cartridge. Try replacing the cartridge and power cycling the copier before placing an expensive service call.
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
Do all documents have this problem? Then I would contact an authorized Sharp repair center.
If there's only one document that does this, it could be a corrupt or very large file that the printer can't handle. Try sending a single page of the document instead of the whole thing.
Isn't the AR-M350U a "Corporate" multifunction device? Then your vendor should be providing warranty support or service contract support for it. Check with the vendor before getting involved with another company.
