you have a convergence problem
it will have to have a couple ics and possibly some resistors and pico fuse
if you have a soldering station and the tools you may want to try this repair your self if not then you may want to enlist the help of a local servicer
cost depending on area 300 to 360.00
I have a Sony 65" projection TV. The screen turns green and then after a few seconds goes...
(More)
I have a Sony 65" projection TV. The screen turns green and then after a few seconds goes black. The light on the front of the tv flashes 7 times. Does anyone know what this means?
sony kp-65wv600 projection tv error code 7 (light on front flashes 7 times) after picture turns...
(More)
sony kp-65wv600 projection tv error code 7 (light on front flashes 7 times) after picture turns completely red and then cuts off.
Started with red lines, then red picture and now the standby is blinking 5 times. TV still turns on...
(More)
Started with red lines, then red picture and now the standby is blinking 5 times. TV still turns on but no picture.
My Sony's Convergence AD Board (Regi Correction) was replaced once and I suspect the same problem...
(More)
My Sony's Convergence AD Board (Regi Correction) was replaced once and I suspect the same problem happened 2 years later. Old AD Board Part # A-1300-411-A A1300411A Replacement Board# A-1300-887-A A1300887A It appears the Resistor at R9524 is burned, but I cannot tell. It's a light blue resistor with 331J *38 on it. Can anyone tell me what the value should be? How can an AD Board be fixed?
Help needed! I had a blue tube replaced (had the blue line across the screen no other color or...
(More)
Help needed! I had a blue tube replaced (had the blue line across the screen no other color or picture) and a year later the green went down. Service man adjusted it but it still had a green "halo" all around everyone in the picture. We have been unable to locate a green tube, even the place Sony said had one in stock locally, said they do not. I replaced the TV with a flat screen that has an excellent picture but my wife wants to Sony back in working order. Anyone know where the part can be obtained? I have cruised Craigs list but am not interested in buying a parts TV for twelve hundred which is what they are asking around here. I am in Austin TX.
