I have a Bulova wall clock. The hands setting disk only moves the minute hand. The hour hand must be moved manually. I have it set to chime every 15 minutes. However, the hour chimes on the half-hour and, for example, at 3:30 it chimes 6 times, 4:30-7 times, etc. Any way to set this correctly without installing a new time piece? It does keep good time otherwise.
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate...
(More)
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate observation.
To remove the spring clip that hold in the battery and plastic, place your thumb over the middle of the spring and gently press and slide the spring in a 7:30 to 1:30 direction. The spring pops out and the battery can be removed. NO PRYING IS NECESARY. Replace the battery. The spring is replaced by setting the 7:30 end in place and then sliding the 1:30 end in to lock it.(similar to the removal but in reverse). I hope this helps!
I have an inexpensive Sharp digital watch which I'm having problems setting the time because I've...
(More)
I have an inexpensive Sharp digital watch which I'm having problems setting the time because I've lost the instructions. On the back of the watch is this information: Sharp, SHP3232, 285, China Module.
the coating on the silver watch band seems to have eroded and now its irritating my skin. would like...
(More)
the coating on the silver watch band seems to have eroded and now its irritating my skin. would like to return, received as gift
