Question about Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1050 not turning on
Hi
my washing machine, zanussi aquacylce 1050 is not turning on.
there is no light when I turn to the program and pull out dial to turn on - nothing happens - any ideas?
ABY
  • el_ayoun Sep 21, 2008
    i have bought exactly the same model in used conditions and when i did try to turn it the same happened..no lights no move. did checked all suggestions but no solution yet, any idea?
    President:
  • 1,294 Answers
First try another gadget, a lamp or something on the wall plug, to see if the point is live. Then check your washer plug, could be that the fuse in the plug has blown, check out your washer wire....
Posted on Jan 06, 2008
Zanussi aquacycle 1200 want open
H? there
This somerimes happens t? my Candy, then I d? the same ?s you.
I also turn to off, wait the desired two minues> turn to empty, most often she does as she is told> turn off, wait the two minutes> turn to spin, turn off> wait the two minutes. This usually works and then I can put on any program. This works for me. Hope you find a solution for you,
kolbrun
Feb 04, 2015 | Zanussi Washing Machines
I have a zanussi 1600 aquacycle. We had a power cut then the machine wouldn't empty so I emptied it manually and now the door won't lock to start any programmes. Any suggestions??
turm the power off
then press in the two buttons on the left hand side while pressing them turn power back on turn selector to one oclock{if you have buttons to select programs press it } you should see the lights come on and move to different programs this is a test program to take it off test turn to off then turn anti clock wise
Feb 03, 2015 | Zanussi Washing Machines
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
I have a Zanussi FLS1183W aquacycle 1050 washing machine. It has stopped spinning and I suspect the carbon brushes. How do I access the motor to examine/replace the brushes?
There is no solid base to this washing machine so if you simply lie the machine on its side you can access the motor from underneath.
Jun 01, 2010 | Zanussi Washing Machines
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
264 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
