LEDs for the ports with cables are lit. If not, move the cable to a different port. there are still no lights,
LEDs for the ports with cables are not lit. move the cable to different ports. and there are still no lights, netgear DG834Gv3
  • colynescott Jan 06, 2008
    iv tried router on laptop router is fine. it VIA VT6105 Rhine III fast ethernet. its installed proply but has no connectivity. so it means when i plug ethernet cable to computer then into router it is not registering on router ( as if no info going through)
  • colynescott Jan 07, 2008
    thank you for infomation it looks like i need a new 1
    Novelist:
    Scholar:
  • 117 Answers
What are the other ends of the cables connected to?
Are the other devices switched on?
Stupid question perhaps, but are any other LEDs on the router on?
Was it all working before or is this a new installation?
Posted on Jan 06, 2008
  • Dave Harris
    Dave Harris Jan 06, 2008
    Some of these are very obvious but can be easily overlooked (done it myself :).
    (a) If it's a motherboard mounted socket, then check the BIOS settings for the ethernet.
    (b) The ethernet driver on the PC may be corrupt and therefore not enabling the card. Go into Device Manager and delete the Ethernet Interface. Reboot the machine and allow it to reinstall the driver. (It's not the actual driver code that gets corrupted, it's data about/for the driver held in the registry).
    (c) The interface has died. Rare but it does happen. A new card is around £6 - 10 in the UK. Fitting it is reasonably simple but a local independent PC shop will do it for you for very little (not PC World!!)
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
Only the printer led is lit
Are there any lights on? If not, then have you checked the power supply, and the wall sockets. Sounds like that may be your problem?
Feb 25, 2010 | Draytek Vigor 2910G Dual WAN secure...
I'm installing an old D-link DI 634M a friend gave me. when I have it all set with the e-net cable coming from my cable modem, I can access the web by logging in over the wireless part of the D-link (with...
You said you can get connection coming from modem directly? Or did you mean the modem is going into the wan port of the router?
Did you try all the ports on the router?
Did you check the cable?
Did you try turning off the wireless on your the pc and connecting via e-net cable?
Make sure it is not the pc or cable.
Also, check and make sure a firewall is not waiting for you to add it to the trusted sites list.
Are you getting an IP when you plug in the cable and are the lights lit up on the router and nic?
I would make sure you got a connection to those ports via another computer before moving on, and try using all the ports with a different cable if possible.
Oct 04, 2009 | D-Link DI-634M Wireless Router (DI634M)
HOW TO CONNECT IT TI A COMPUTER?
When the computers are powered up and connected to the D-Link hub,
the computers that are connected to the hub will light up the various LEDs on the hub to indicate which port on the hub is active. Also that computer's network card Link LED light should be on to indicate it is connected to the hub.
If the hub's LED is off and the corresponding computer's network card Link LED is off then the network cable is faulty, or the network card is faulty (or the network card driver needs installing) or the port on the hub and/or hub is faulty.
To determine which item is faulty, swap network cables around, swap computers to different ports on the hub etc
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
No lights
hello!
Is there a computer connected directly to the router? Possible that the router do not detect any physical connection on it. if none of the number light light up it means that there might be no computer directly connected to the router .
Have you tried connecting your computer to a different port? how about using a different cable? How about a different computer? if theres a computer connected to it hardwired but still no light, try to connect your computer to the other ports of the router and check if the lights will come on. if not, try a different cable and a different computer. Possible that t could be a defective port, defective cable, defective lan card or the driver of the lan card on the pc is not properly installed that's why the pc is not detected
Aug 27, 2008 | Belkin (F5D7230-4) Router (587009)
Pixma 160
Chances are you reconnected the printer to a different USB port and your default is still set up for the other port...
Look at your printer settings and chances are it set up the printer again for the new port.
Either change your default printer or move the cable back to the original port.
Jan 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Cannot Log on to my Router
These steps solve most of the problems with logging on to routers. 1. Connect a computer and a router directly with an Ethernet cable, putting an end in one of the router's LAN ports. Check that both ends are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot the light status, as explained in the manual. 3. Check that the LEDs for the ports with cables are lit. If they are not, try moving the cable to a different port. If there are still no lights, then troubleshoot the light status, as explained in the manual. 4. Check the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue with this document. If the Ethernet adapter was not made by NETGEAR, contact the adapter's maker. 5. Select Start > Run. Type cmd. Type ping 192.168.1.1. If there is a message "Request timed out", type ping 192.168.0.1. If that also has a "Request timed out" message, then your computer is not making a connection to the router. 6. Otherwise, your computer is connected to the router: * Make sure proxies are not enabled. If using Internet Explorer, select Tools > Internet Options > Connections > LAN Settings. Uncheck "Use a proxy server for your LAN....". * Delete offline contents. Select Tools > Internet Options > Delete Files. Select Delete all offline content, and click OK. (This is to clear any possible previous router log on page.) * Try accessing with a different computer, or with the Netscape browser, if you have it. * Delete cookies. WARNING. Do not do this if it's possible Web sites you visit need cookie information such as your logins and passwords. 7. Power off the router, and power it back on again. 8. If you still cannot log on to the router, then do a hard reset on the router. (Described here: http://www.fixya.com/ThreadView.aspx?thi...) 9. If you know how, check the computer's IP address and DHCP. The IP should be in the 192.168.0.x range, and DHCP should be enabled.
Feb 19, 2006 | NetGear RP114 Router
These steps solve most of the problems with logging on to routers. 1. Connect a computer and a router directly with an Ethernet cable, putting an end in one of the router's LAN ports. Check that both ends are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot the light status, as explained in the manual. 3. Check that the LEDs for the ports with cables are lit. If they are not, try moving the cable to a different port. If there are still no lights, then troubleshoot the light status, as explained in the manual. 4. Check the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue with this document. If the Ethernet adapter was not made by NETGEAR, contact the adapter's maker. 5. Select Start > Run. Type cmd. Type ping 192.168.1.1. If there is a message "Request timed out", type ping 192.168.0.1. If that also has a "Request timed out" message, then your computer is not making a connection to the router. 6. Otherwise, your computer is connected to the router: * Make sure proxies are not enabled. If using Internet Explorer, select Tools > Internet Options > Connections > LAN Settings. Uncheck "Use a proxy server for your LAN....". * Delete offline contents. Select Tools > Internet Options > Delete Files. Select Delete all offline content, and click OK. (This is to clear any possible previous router log on page.) * Try accessing with a different computer, or with the Netscape browser, if you have it. * Delete cookies. WARNING. Do not do this if it's possible Web sites you visit need cookie information such as your logins and passwords. 7. Power off the router, and power it back on again. 8. If you still cannot log on to the router, then do a hard reset on the router. (Described here: http://www.fixya.com/ThreadView.aspx?thid=102071&prdid=252225) 9. If you know how, check the computer's IP address and DHCP. The IP should be in the 192.168.0.x range, and DHCP should be enabled.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Computers & Internet Logo
112 people viewed this question
Alun Cox
David Payne
David Payne
