Mitsubishi WS-55511 55 in. Rear Projection Television
Problem for Mitsubishi WS-55511 55 in. Rear Projection Television
The picture shows double
By autoprotx on Nov 08, 2009
Solution #1
posted on Nov 08, 2009
Not Rated)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 1149 votes
WS-55511 USES a single STK-393-110 convergence IC.
If convergence if off and either blue or red will not adjust in some direction--The chip and any of the 3.9 ohm resistors around it that protect it--will need to be replaced if they are bad.
Most of the time--just the chip needs to be replaced and the set adjusted.
I have step by step, start to finish instructions for this repair in this type of set.
If you can do the repair, total parts cost will be under 25 dollars--you can buy the chip on Ebay and the resistors are easy to check.
I have photos of the resistors and the instructions tell you everything you will need to do the repair.
If you cannot do the repair--most shops are going to get 300 or more for it---if you go that way make sure you get someone to do it--it should be able to be done right in your home--takes about 1 hour--I know as I have done HUNDREDS of these sets with this problem.
If this information helped you rate this solution as I do this here for free.
If you need the instructions let me know and we will find a way to get them to you....
SD TECH
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-55511 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55511 55 in.
Do you recommend Mitsubishi WS-55511 55 in. Rear Projection Television?
Answer
Answer
my nephew thought it would be fun to shoot the deer on the TV with his airsoft pellet gun... one of... (More)
Answer
I have a red line shadow on the right side of the picture
Answer
I have a Mitsubishi Model- WS-55511 projection TV. The picture is really jiggling until I opened the... (More)
Answer
I have a Mitisubishi rear projection tv. When I turn the power on, the power will go off in just 2... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
