Question about Dell 1700n Laser Printer
Dell 1700 Transfer Roller
Please help to get Dell Part # for Transfer Roller for Dell 1700 Printer 110V
  • 1 more comment
  • PRAS123 Jun 02, 2008
    I HAVE A PRINTER DELL 1700, WHICH CANT PICK UP THE PAPER I THINK THERE IS SOME PROBLEM WITH MY PICK UP ROLLER CAN YOU GUIDE ME ANY SOLUTION
  • vanderlm Jun 03, 2008
    I believe I have a similar problem the paper curls but doesn't continue and then shuts down flasing "paper jam" it is not jammed but wont continue along the paper path...please help
    -mike
  • Anonymous Aug 16, 2008
    same problem no solution
    Scholar:
  • 97 Answers
These series printers have a typical problem of the paper pickup rollers wearing out resulting in jams, crooked feeds and partial feeds. a quick fix:
take the paper tray out, turn the printer on edge and locate those two rubber roller bands on the pickup arm. Peel them off, flip them inside-out and return them to the rollers. This restores thier sticky rubber side so the papper feeds properly.
Now if you are a heavy printer, you can order some of these from dell for the next time. Washing these in handsaop and water works sometimes too. never use alcohol.
Posted on Dec 24, 2008
PRINTER IS PRINTING OUT PAGES WITH DARK SMUDGES FROM ROLLER. DELL LASER PRINTER 1700.
toner spill on the paper path. this occurs mainly due to 0verfilled toner cartridges ( refills) use damp cloth or metho damped cloth to clean the rollers in the paper path.
Please rate my help++++Thanks for using FIXYA
May 20, 2010 | Dell 1700n Laser Printer
Tip
Replace Transfer Roller
If the printer still says to replace transfer roller even after it's replaced, then remove transfer roller and manually turn the gears on the transfer roller a few times. It must get stuck or something. Then replace the transfer roller and it should work.
on Feb 07, 2008 | Dell 5100cn Laser Printer
Our Dell 5110cn stopped working and the 'diagnostic' said to replace the transfer roller. I had purchased a Dell Imaging Drum and replaced that. I believe it has a transfer roller as part of the Imaging...
Dell sells the drum & transfer roller a kit, but there are 2 different parts to it, the drum & the transfer roller & they do not look the same. Replacing the drum does NOT replace the transfer roller. We've had a 5110cn for 4 years, I've replace both of these parts & the fuser unit several times.
May 07, 2010 | Dell 5110cn Laser Printer
My Dell 1700n Drum and Toner Cartridge were both replaced when the drum replace light blinked and the print was getting lighter. Despite resetting the Drum counter the printer still only prints faintly...
Have you checked the fuser?
A laser printer fuser assembly is the heating roller unit that melts and fuses the toner onto the paper. The fuser assembly is made up of a heating roller and a pressure roller.
The heating roller applies the heat to the toner on the printed page and the pressure roller presses and fuses the toner into the printed page. If it's bad and not heating properly, the print will be faint, which is what you describe. You may be able to remove and clean the fuser, but if the printer gets lots of use, it may just be worn out.
See this link for an idea of what it looks like and a price.
http://www.fastprinters.com/ProductDetails.asp?product_id=DELL-H4919
I do not work or represent this company, so shop around.
Mar 22, 2010 | Dell 1700n Laser Printer
I replaced the transfer belt and the printer prints now. However, the unit that heats has a black ring on it which transfers to the paper that prints. What part needs to be replaced now?
If you are Talking about the Fuser ***'y
MEA ROLLER (RED IN COLOR) IT'S LIKE A THICK RUBBER - which you can clean it with the Spirit need to clean this part
RCT-ROLLER HEAT (it seems fine)
ELA HOU-FUSER 220V 0r 110V (it seems fine)
LAMP HALOGEN 220V/110V (it seems fine)
Jan 21, 2010 | Samsung CLP-510 Laser Printer
REPLACE TRANSFER ROLLER
Replace transfer roller means you need to order a transfer roller for your
dell printer. your best bet is to go to www.dell.com and order the trasnfer roller for your printer.
thanks adi
Jan 15, 2010 | Dell 5110cn Laser Printer
Is transfer roller available separately. dell only sells it with imaging drum
it does work we have both models and the transfer rollers are interchangeable between the 5100 and 5110.
Oct 02, 2009 | Dell 5110cn Laser Printer
Dell 3100cn
the BTR cover is also called " Bias Transfer Roller " cover it should be that roller that seen when open the front cover most likely the Bias transfer roller door sensor in NOT detecting the dorr closed. make sure the tab isn't broken this will produce this error if it is.
Jul 23, 2009 | Dell 3100cn Laser Printer
Does not pick up paper from the tray
How much paper gone throught the printer since it is new?
usually the pickup roller is good for 10,000-15,000 sheets.(20x500 sheet pack). if the printer went throught that much paper, then the pick up roller need to be replaced.
if not, make sure there nothing stucked on the pickup roller, and the roller is not shining (it need to be soft and rough).
Apr 18, 2009 | Dell 1700 Laser Printer
Lexmark Z45 drivers needed for mac
The mac driver for the Dell 1700 is Lexmark 332N. The mac driver for the Z45 is on the Lexmark web site.
Feb 24, 2008 | Dell 1700 Laser Printer
Dell 1700n Laser Printer Logo
314 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
