Panasonic PT-47WX53 47 in. Rear Projection HDTV Television
Problem for Panasonic PT-47WX53 47 in. Rear Projection HDTV Television
How do i fix a projection hdtv the picture looks
By vickman68 on Nov 08, 2009
how do i fix a projection hdtv the picture looks pintched in middle red green and blue lines at bottom
Best Solution
posted on Nov 08, 2009
Helpful)
SD Tech
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 97%, 1172 votes
IF MODEL NUMBER IS PT47WX53:
If you have gone into the customer menu and CONVERGENCE is skewed and will not adjust:
One or both of the two STK-392-110 convergence chips that this set uses are bad.
The chips are about 2 1 /2 inches wide by 1 1/2 inches tall and are black in color. They are mounted on metal heat sinks with fins and are side by side--they will have the Stk-392-110 number printed on them in white letters.
If you locate them take a good look at all the light blue resistors in front of them--most are marked 2.2 ohms---look for any that are white or discolored in the middle---if you find one or more YOU HAVE FOUND YOUR PROBLEM.
BOTH chips and any bad resistors need to be replaced and the set adjusted. If you can do this repair you can save a lot of money as you can buy both chips (a pair) on Ebay for about 12 dollars plus shipping.
I have start to finish instructions for this repair on this type of set.
If you cannot do this repair yourself, shop around your area--most shops charge 300-400 for this kind of repair--I do them here for 200-250 and have done hundreds of them.
If they say it has to go to the shop--keep looking as any good tech can do this repair in your home in about 1 hour.
If you have any questions or need advice reply to this posting here OR check out all my many solutions here for more information concerning what I have told you.
I am here to help people. If this information was helpful rate this solution as I do this here for free.
Regards, SD TECH
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Somewhat Helpful)
asnowman
Rating: 95%, 607 votes
What you might be experiencing based on your symptom sounds like a damaged convergence IC.
With any Projection Television that has a damaged convergence IC, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-47WX53 47 in.
Questions and Unsolved Problems for Panasonic PT-47WX53 47 in.
Do you recommend Panasonic PT-47WX53 47 in. Rear Projection HDTV Television?
Answer
Answer
I have a couple lines inside the screen of my Panasonic Projection TV. I think that it might be some... (More)
Answer
i have a Panasonic PT-47WX51ce rear projection tv when i press the power button it comes on for... (More)
Answer
our tv picture is only coming in red and green. what is the problem?
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
