John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Problem for John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a John deere 317 tractor that does not start.
By lbeauchane on Nov 08, 2009
I have a John Deere 317 tractor that does not start. The engine turns but does not fire. The plugs and points are good. I do not get a spark at the points or plug. What should I check next next.
Solution #1
posted on Nov 08, 2009
Not Rated)
rwvanlue
Rank: Guru  Garden Tools  Expert
Rating: 91%, 127 votes
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Was this helpful?
Yes
No
Popular Solutions for John Deere
Questions and Unsolved Problems for John Deere
Do you recommend John Deere 420,1020,2010,2020,2510,2520 Tractor Float?
Answer
Answer
need a schematic for a john deere 1020 diesel farm tractor - trying to replace alternator belt
Answer
i bought this 1961 ru 2010 that ran great, but needed some tlc, after making the repaires in the... (More)
Answer
I am repairing a coolant leak on my old John Deere 520. I installed 2 new o-rings in the groves... (More)
Answer
we just purchased a 7775 skid steer and want to know where the plug in is it seems like it may be... (More)
Describe your Riding Mowers and Garden... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Riding Mower and... Experts
Top Garden & Power Tool Repairmen
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
