Toshiba Satellite A100-S8111TD - Laptop Customizable  PC Notebook
Problem for Toshiba Satellite A100-S8111TD - Laptop Customizable...
Ok... so i had a problem earlier with my toshiba
By oinarisama on Nov 08, 2009
ok... so i had a problem earlier with my toshiba satellite pro involving hibernation, but now it wont boot up when i turn it off, or put it to sleep either... the power light comes on, but nothing works. when paper clip-opened the cd drive to use a recovery disk, it didn't read it... and when it does start up, it just freezes... >.> i think that's all (vista, and it's actually a200-something)
Comments:
Nov 08, 2009
- yes, i mean i can't even get into the bios... and it a toshiba satellite pro a200-01h... if it matters any >.>
Nov 09, 2009
- ok, i got some new memory, but that didn't change anything.
Nov 10, 2009
- well, yeah, i will keep trying.... the tech guy we took it to thinks it's the motherboard
Nov 12, 2009
- ok, now the power light flashes orange twice, then blue once... regardless of whether it's on or off.
Nov 13, 2009
- and it says that guy doesn't do canada... >.>
Nov 16, 2009
- ok then...
Solution #1
posted on Nov 08, 2009
Not Rated)
aholic_2
Rank: Wiz
Rating: 85%, 12 votes
OK 3 things needed to boot a PC...
Memory, Video and CPU...
Easiest thing to do first is try and swap out a memory stick. Hopefully you have a burnt out stick of memory.
Open the memory slot and hopefully there are 2 sticks try one then the other.
When you say nothing works I am assuming you can't even get into the bios.
If you are talking about not booting to windows that is a completely different story. But for now I'd try the memory thing.
Comments:
Nov 09, 2009
- Ok please try to swap out the memory first ...
That is the easiest least expensive way to begin ..It really sounds like a memory problem to me..
Is that possible..Let me know ..hopefully you have 2 sticks in there now and only one went bad.
do you have any way of getting your memory tested?
Nov 09, 2009
- Now that memory is out of the way...you did say at times it will start then freeze up...
Keep trying to get it to start...right after the bios loads hit F8 and see if you can get it to boot into safe mode
Is this doable or no way?
Nov 15, 2009
- Hey wait I am sorry I got tied up for a couple days after further study this is a common problem with the a 100...I had all the info ready to post for you...And i got busy and it
Nov 15, 2009
- Wait after further research on the A100 that is a common problem I had all the info and diagrams then rebooted and lost all. I will get them again give me a little while. It is either the power jack needs soldering which is very easy fix or overheating because of bad fans or dust, all the same symptoms as yours were described, let fins the article again, even gave diagrams of how to fix.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A100-S8111TD
Questions and Unsolved Problems for Toshiba Satellite A100-S8111TD
Do you recommend Toshiba Satellite A100-S8111TD - Laptop Customizable (PSAA8U0GX00V) PC Notebook?
Answer
Answer
monitor wont work toshiba satelite laptop turn it on runs but it wont come on i cleaned the hinges... (More)
Answer
my laptop cant download internet files i dont why but it is not working.pls help me.
Answer
note book is not like a desktop computer @ all y because it is a carrying tool and it cost a lot all... (More)
Answer
my screen lamination starts to warp and the edges are starting to peel off.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
