Question about Dynex DX-UC104 (DXUC104) Serial Adapter
Problems loading Vista
Don't know if you can help or not but I am having a problem loading vista from scratch on a new pc. This is the second time I have loaded vista, so I know the spec of the PC is goo and all part bought are vista ready.
The problem I have is that when I install vista it goes through the first 4 stages, expanding, applying updates.....then reboots, after the reboot it looks like its going to work in that I get the green progress bar at the bottom of screed, but then it blue screens on me, indicating that it could be a hardware fault. Now the strange thing is, if I don’t change anything but the DVD and replace the vista cd with the windows xp cd and go through a fresh install deleting all partitions formatting drive and installing from scratch, it works fine.
In addition if I take the hard drive out after loading vista and put it into one of my other pc, vista continues with the install and successfully completes.
I can't work out for the life of me what I am doing wrong and would be grateful for any help.
  • Pacsl Jan 06, 2008
    Thanks,
    I should have said that the version was Windows Vista Ultimate,
    this is a full verrsion, not an upgrade (OEM)
    Thanks for trying.
What edition of Vista do you have? Without full version you can't put vista on first. You will need to have an old windows virsion like 98, 2000, .xp
Vista has about 7 differt Editios exp Home version complet, or upgrade,
Prof upgrade, or profel
if you have bought upgrade profl. You will need to have an old op of xp prof.
Posted on Jan 06, 2008
Windows vista activat again
This is helpful to you :
http://support.microsoft.com/kb/314503
OR
After you get the blank screen, ( After logging in. )
Press either Ctrl+Shift+Esc, or Ctrl+Alt+Delete.
Once you do that, the task manager should open up.
Once open, go to processes and look for Explorer.exe, You might not find it, Because sometimes apparently Vista forgets to start it.
If it is there, Right click it, and End Process.
Once done, ( Follow this step if it isnt there also. )
Go to the Applications tab, and click 'New Task...'
Type in Explorer.exe
This should force the GUI to load, and you shouldnt have any problems from there...
If your computer is new, I'd suggest getting the new Drivers also, as this may reduce the number of times you'll have to do this.
Jan 21, 2010 | Dell Inspiron 1525 Notebook
Tip
Troubleshooting 101
Fix common PC problems Having trouble with your computer? You've come to the right place. Even if you don't know a computer language (or want to), you can solve several common PC problems on your own.
F1 is magic: Get help on your PCtroubleshoot.jpgIf you can’t figure out how to complete a particular task in your software program—and you’re using a PC—the most important shortcut to know is the F1 key. Just push it while the program—Word, Excel, or whichever program you’re using—is open and active, wait a moment, and the Help window specific to your active program will appear. The F1 key works with almost all Microsoft products, so it’s a helpful starting point for a wide variety of problems.
In this article, we offer many ways to do what you need to do in Windows 7 and Windows Vista. Often, there may not be a Help topic for Windows XP, but the process is often the same as in Windows 7 or Windows Vista. The only difference is usually where to find the link in Control Panel. Most often, it’s just a matter of slightly different wording in the heading or the text describing the task. Don’t worry. If you search in Control Panel, you’ll usually find the link you need.
The basicsIf you’re encountering a different kind of obstacle – your new device won’t appear on your desktop, an application you added won’t run, or your computer is refusing to start up – here are a couple of preliminary steps:
  1. Before adding any major hardware or software to your system, make sure you've recently backed up your Windows 7-based PC or your Windows Vista-based PC as a safeguard. By using the automatic backup functions, you can schedule regular upkeep for maximum convenience.
  2. Write down the contact information for Microsoft Customer Service and Support, should you need to consult an expert. Take a second to print the below instructions as well, and keep them handy as you walk through the troubleshooting process.
  3. Many issues can be resolved by simply checking to be sure that all of your plugs are connected properly. After you are sure of that, try restarting (“rebooting”) your system. Turn your computer off, and then back on a few seconds later. If the problem continues, follow the steps below.
Locating the problem Ask yourself if the problem is related to hardware, software, or the operating system (such as Windows 7, Windows XP, or Windows Vista). The following are some common indicators that can help you decide which is the right answer.
If you're uncertain, don't worry. Just start at the top by determining if your software is working, using the Software errors section that follows. If the issue persists, proceed to the Hardware trouble section and then to the System failure section.
You can also find really helpful information at Microsoft Help and Support. If you'd like to search by individual program, try the Product Solution Center. Or check the columns and blogs found on the Windows Community Web site, where you can find helpful input from experts and fellow computer users.
The lists on the right side of this page may also help you narrow down the type of trouble you are experiencing.
Software errorsIf programs refuse to install, won't appear on your desktop, can't seem to run without freezing, don't load at a decent speed or function properly, or Internet access is unavailable, here's how to troubleshoot:
General issues
  1. Confirm that your PC meets the software's minimum system requirements. If it doesn't, you'll be unable to run the program without upgrading your computer's hardware. Note that PCs which barely meet or just slightly exceed these minimums may run the software more slowly and can be less reliable. Windows 7 and Windows Vista users can reference the Windows Experience Index to quickly gauge their PC's general capabilities.
  2. Check for compatibility with Windows 7 and Windows Vista.
  3. Close open programs and windows that you're not currently using. These can eat up system memory and processing power, slowing your PC or preventing additional software from running. Try running the program again.
  4. Check available hard drive space. Roughly 5 to 10 percent of your hard drive's total storage allotment should be left free to ensure optimum system performance in Windows 7 and Windows Vista, prevent crashes, and keep Windows running at top speed.
    Note Use Disk Cleanup to free more space:
    Windows 7
    Windows Vista
    Windows XP
    Check for program updates and information on frequently encountered issues at the software manufacturer's Web site. For Microsoft products, you can also load Windows Update for Windows 7, Windows Update for Windows Vista, or visit the Microsoft Download Center. If you install an update, restart your computer, and attempt to run the program again.
  5. Uninstall or delete unwanted programs in Windows 7 or Windows Vista to cut down on clutter and remove any drain on your system's resources.
  6. Disable programs you don't use to in Windows 7 or Windows Vista by preventing them from automatically loading when Windows starts. If you’re running Windows 7, restart your computer, and try the program again.
  7. Defragment your hard drive in Windows 7 or Windows Vista to improve performance.
  8. Scan for viruses and spyware. Windows Defender in Windows 7 and Windows Vista can help detect and prevent threats, along with preventing annoying pop-up notices and unauthorized home network intrusions. You can scan your PC for free.
  9. Reboot your computer and try loading the program again. If it still won't load or work correctly, you may need to uninstall the software and then reinstall it from scratch and reboot again. Advanced users can also try these advanced troubleshooting tricks in Windows 7 and Windows Vista.
  10. Consult Microsoft Help and Support and the Windows Community. If live assistance is required, first contact the software manufacturer's customer support department. For additional assistance, try Microsoft Customer Service and Support.
on Jan 17, 2010 | Computers & Internet
Have an hp pavillion a6319fh boots to blue screen and curser
Could be alot of things, Scratched , even a small pinprick on the CD, or you have some bad ram, or your Hard drive is going. Thats the thing about troubleshooting a PC.
Sep 22, 2009 | Computers & Internet
I have used my 3com office connect for router with
from my own expierence ive learned that vista supports very few programs. why i dont no. ive had the same problems my husbands pc runs windows xp and the router links to his no prob. try goin on thte router site and down load a new driver from the vista pc. and try reloading if not im sorry but you will have to purchae a newer router vista compadible
Sep 13, 2009 | 3Com OfficeConnect Router
Rome Total War!‏
That is your problem. If the game is not compatible with Windows Vista, It won't play it, or play it normally. What I mean is that the game is pretty old (in date created), and the software used to create it was not meant for Vista. Because Vista came afterwards (I think). And Vista has to downgrade while running the game. But it could only downgrade so much. And when it downgrades, it's actually working harder to play the game than having a whole bunch of stuff open at the same time. Vista playes it, but only for a while, because it's not going to downgrade any more.
Hope this helps.
P.S. If you want to play the game, I recomend you get a computer with XP.
Apr 30, 2009 | Sega Genesis Console
Installing problems
If you are working with Microsoft Vista, then take your pc or notebook back to the company you bought it that they can reload Vista. It is probably a software problem. With me it installed etc and i can print, but each time that i must plug in the printer usb cable in my notebook, it tries to install it again. Finally goes the reason, Vista software problems.
Jul 11, 2008 | HP Officejet 6310 All-In-One InkJet...
Installing Problems
It's a hardware incompatibility with windows vista. for example your graphics card on your Inspiron might not be fully supported in windows vista and your Laptop's graphics card is supported by Vista. Most of the times we can find this incompatibility is with graphics cards. Download and install the newest drivers for your inspiron's graphics card. I have seen your inspiron has an ATI Radeon X1300 graphics card. The windows Vista drivers can be downloaded here http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista32/common-vista32
Oct 10, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Loading windows anytime upgrade
Hi, Unfortunately Microsoft has blundered and not told anyone. Most older programs will not run in VISTA. I hope you burnt your download to a CD, you could use it at a later date when Microsoft finaly put VISTA right. At this time you only have two choices. Buy all new software that is VISTA compatable or go back to the good old faithful XP. Regards mistyman
Aug 20, 2007 | OfficeMax Hewlett-PackardHP Pavilion...
Dynex DX-UC104 (DXUC104) Serial Adapter Logo
109 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
