Question about Technics SL-1210 Turntable
I need instructions for replacing rca plugs on technics 1210 mk3 s
    Novelist:
    Champion:
  • 382 Answers
Http://www.repairnyc.com/
Strike while the soldering iron is hot.
Posted on Jan 14, 2008
F1 Blowing after replacing RCA cable Technics
ability to switch between 110 and 220 voltages. is it set at the wrong setting to power on? why did you need to replace inside wires? maybe something was touching inside and has blown the fuse. see legitimate repair shop.
Sep 11, 2012 | Panasonic Technics Sl-1210 Mk2 Turntable...
My 1210 mk3's keep's popping the internal fuse?
Sounds to me like the capacitor across the motor needs replacing. On the + and - on a motor is a capacitor. This might be the problem, replace it as it should not be too expensive, you can never tell. Some times they are a few pence other time they are a few pounds. Why I don't know. If it's a common one, a few pence if it's a rare one, pounds....... I hope this helps.
Jun 29, 2012 | Technics SL-1210 Turntable
Internal fuse on Technics 1210 Keeps Blowing. Hi there, I have been asked by a friend to repair his decks, I have little electronic knowledge but am having a crack at it any way :) Problem is the Fuse F1...
this was happening last mine with mine aswell i just replaced a fuse then it started to work??
One fuse had colouring on it which i did not know what it meant sop i didnt touch that.
So have you changed both?
Oct 20, 2011 | Technics SL-1210 Turntable
No power when i turn on my mk3 turntable
Check the internal fuses. There are two. You have to strip the unit down to get to them.
This video will show you what's involved:
http://www.youtube.com/watch?v=CDYgjwdQ55s&feature=channel_page
Aug 17, 2009 | Technics SL-1210 Turntable
Had to replace stylus on SL-B2. Arm was "skating" across disc but seem to have that fixed. Sound definitely not correct. What can I adjust?
Hi sounds like the cartridge or stylus are not seated correctly or at correct angle (cartridge).
Also weight/balance and anti skate need adjustment. Try getting the manual and using that to set it up correctly - no easy task though as lotsa info there.... :) Manual for 1200 MK3 will do as well. Hope that helps
Jul 15, 2009 | Technics SL-1210 Turntable
Poor quality sound
Double check all your cables. The only 2 things that affect sound on the 1200s is the RCA cables and the tonearm. I would first replace the RCA cables to a better quality set.
- OPTiC
Technics Repair Videos
Technics Turntable Repair
DJ Equipment Sales
Technics Parts Sales
Jan 16, 2009 | Technics SL-1210 Turntable
Technics Trouble... Please Help
You will have to replace the RCA cables on your turntable. You can try to do this yourself, however soldering experience is required. You can purchase the parts HERE - and install yourself, or try to find a reputable service center area to replace the cables.
A word of advice, try not to use the original RCA cables that are installed with the turntables, as they aren't of the greatest quality. Try and put a better brand, or use the MOGAMI cables, available HERE.
Have fun!
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 20, 2008 | Technics SL-1210 Turntable
Technics 1210 feedback problem hollow noise ??
More than likely it's your RCA cables, or it could be a tonearm or cartridge issue. First try and swap out the cartridges on your turntable, and see if the problem persist. If it does, then you can narrow it down tot the tonearm and RCA cables. Since the RCA cables are easier and cheaper to replace, I would suggest doing this first - You can try to do this yourself, however soldering experience is required. You can purchase the parts HERE - and install yourself, or try to find a reputable service center area to replace the cables.
If the problem persists, then the issue with your tonearm, and replacing the tonearm involves a lot more in-depth work, and I would only suggest having it done by a profession. You can buy the part HERE, and bring it with you to the service center, to minimize your cost.
There is nothing else that would cause this kind of problem except one of the 3 (or combination). So, by a process of elimination, you'll solve the problem.
Have fun!
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 16, 2008 | Technics SL-1210 Turntable
Major Hiss
The issue could be 1 of 3 things...
1) Cartridge / Headshell
2) Tonearm
3) RCA cables
or a combination.
Hard to isolate the issue. Make sure the cartridge/headshell wires are connected properly. Does the his go away when you touch the tonearm? How about the RCA cables? If so, then that is usually the culprit. Did you buy this new or used? If new, I would suggest returning it, or excersizing the warranty.
If the tonearm is the issue, this is not something I would suggest you replace on your own, as it is rather complicated.
Here is a site to buy all the parts you need for your unit:
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES/c271_272_278/index.html
Just pick the model you need parts for. You can use any good quality RCA cables, but soldering is required in order to replace.
Hope this helps.
DJPROAUDIO
TWEAK AV LAB
Dec 21, 2007 | Technics SL-1210 Turntable
Technics sl 1210 turntable
What sort of problem are you having with the cords?
Sep 04, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
88 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
