Mitsubishi WD-52525 52 in. Rear Projection HDTV Television
Problem for Mitsubishi WD-52525 52 in. Rear Projection HDTV Television
TV makes popping noise and shuts down. picture
By mstiff on Nov 08, 2009
TV makes popping noise and shuts down. picture returns when set turned back on again. after a period of time, it does it again
Solution #1
posted on Nov 10, 2009
Not Rated)
gullipudstvs
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 178 votes
It seems that you have an issue with your ballast. This is the board in charge of sending energy to the lamp so it can light up. It's not a very expensive board, it's pretty cheap actually. http://www.discount-merchant.com/SearchResults.asp?Search=mitsubishi+ballast/?Click=48427
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WD-52525 52 in.
Questions and Unsolved Problems for Mitsubishi WD-52525 52 in.
Do you recommend Mitsubishi WD-52525 52 in. Rear Projection HDTV Television?
Answer
Answer
I have a Mitsubishi WD-52525 and when i plug anything into inputs 1,2,or 3 the screen will start off... (More)
Answer
Turn on tv and nothing but blue screen. Tv menu comes up but nothing else
Answer
Blazz I am trying to get the info youre requesting to help you repair your WD52525 but I keep... (More)
Answer
code resetn ? tv will not come on asks for code
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WD-52525 52 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
