Philips Magnavox 9P6034C 60 in. Rear Projection Television
Problem for Philips Magnavox 9P6034C 60 in. Rear Projection Television
I have a 60
By fggarza on Nov 08, 2009
I have a 60" projection tv philips magnavox model #9P6040 C104 PTV843. The color looks bad, the picture looks orange and red. What do I need to fix it and how much will it be.
Solution #1
posted on Nov 08, 2009
Not Rated)
SD Tech
Rank: Guru  Philips Televisions & Videos  Expert
Rating: 97%, 888 votes
You have one of two problems based on your description.
1.) Go to a channel that is in black and white and turn the color on the set all the way off.
Examine the screen and picture from several feet back----if the picture is mostly red and looks somewhat yellow in the main part of the screen you have a GLYCOL problem.
These sets have on each picture tube a sealed unit full of Glycol to cool the face of each tube (set has a red, green, blue picture tube)
If you find the yellow/orange look with the color off you most likely have bad Glycol in the blue picture tube---it never happens to the red--bacteria gets into the glycol and eventually there is no picture coming from (in most cases) the blue tube.
Loss of blue will leave you with Red and Green--mix those two and you usually get a orange/red affect.
There is a way to also confirm this with your eyes--it involves getting the back cover off of the set and holding a small mirror (with the set turned on--you have to be careful not to touch anything)
If you look in each lens you should see a fine picture--one red, one green and one blue--if as I suspect the blue tube is contaminated it will not have a picture and will look like a blue floodlight.
IF THIS IS NOT YOUR PROBLEM--GO into the customer menu and select convergence--what you are looking for is will red and blue adjust or not--are they skewed and will not move.
If this is the case you have a convergence problem--I can tell you what is involved to fix in either case.
Let me know what you find--I am here to help people.
If this information has helped you, rate this solution as I do this here for free.
SD TECH
Was this helpful?
Yes
No
Popular Solutions for Philips Magnavox 9P6034C 60
Questions and Unsolved Problems for Philips Magnavox 9P6034C 60
Do you recommend Philips Magnavox 9P6034C 60 in. Rear Projection Television?
Answer
Answer
i can adjust the picture (color, bright,, tint, picture, sharp, etc...), it looks to orange. it is a... (More)
Answer
When I turn the T.V. on The screen shrinks and becomes distorted. After it warms up It becomes more... (More)
Answer
picture is lighter and seems to be blue. like one of the tubes is burned out.
Answer
i have a phillips model# 8p6034c an i need the outer screen / protective cover
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips Magnavox 9P6034C 60...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
