Home | GE | Profile Spectra JGBP90 Gas Kitchen Range | Ge x stove, burners wor...
GE Profile Spectra JGBP90 Gas Kitchen Range
Problem for GE Profile Spectra JGBP90 Gas Kitchen Range
Ge x stove, burners work, oven does not, where is
By bobed53 on Nov 08, 2009
ge x stove, burners work, oven does not, where is pilot light for oven
Best Solution
posted on Nov 08, 2009
Very Helpful)
Sassy6
Rank: Guru  GE Ovens & Ranges  Expert
Rating: 88%, 105 votes
I tried to get a picture of the range with you model #, but I think the number is wrong. Maybe you could check it. However, if the oven isn't lighting you may need a new igniter. These are also called glow coils, when they get weak they glow orange and they need to be white hot to ignite the gas for you. Hope this helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 19, 2009
Not Rated)
avid101
Rank: Guru  Ovens & Ranges  Expert
Rating: 87%, 1137 votes
Please go to http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=jgbp90 and select your modelthe metal tag should be on the back of the store and should match one of the numbers there. other than that it is most likely the thermal bulb that is not heating up. it could also not be getting gas due to it not heating it up so check back with us with the number.
Was this helpful?
Yes
No
Popular Solutions for GE Profile Spectra JGBP90 Gas
Questions and Unsolved Problems for GE Profile Spectra JGBP90 Gas
Do you recommend GE Profile Spectra JGBP90 Gas Kitchen Range?
Answer
Answer
It sounds like my oven flame is stuttering. It doesn't maintain temperature.
Answer
how do you get the top off to get at the oven control valve
Answer
the maximum output range flame is to high with a yellow flame
Answer
3 of the 5 burners on my Mabe gas Stove cant be turned up to high heat. I have a manual but it is in... (More)
Answer
how do I delete a message that the door is locked on my ge electric oven display after the cleaning... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile Spectra JGBP90 Gas...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
