Question about Western Digital 250GB ELEMENTS EXTERNAL USB 2.0 250 GB Hard Drive
Western Digital Elements Drive Problem
My USB drive was working properly till yesterday, but when i plug it into my computer today it didn't work at all. just the power led is on but the computer can't recognize that new device was attached !!
please help !!
  • 2 more comments
  • akandil Jan 06, 2008
    thanks , i already cheked it on another system and it couldn't be recognized as well .
    how can i format it while the computer can't feel that a new device is connected to it !!
  • Jay82 Mar 09, 2008
    I have a 500gig elements hard drive, up until yesterday it stopped working. Laptop recognises the hard drive but i cant access it, is there anyway of fixing it without loosing all the info that is on it? If not how is it possible to format it when it only recognises the usb connection and doesnt display the hard drive in My computer? Thanks
  • jennyb10 Sep 23, 2008
    I have a similar situation. My WD 250GB has completely failed. Apparently to retrieve any data I need to find another one manufacturered around the same time. Anyone got any suggestions on how to do this?!!!! It was made on 02 Dec 2006. This seems like an impossible task to me. (But I have 100GB of data that would make it a worthwhile task if I could retrieve it!) Thanks.
  • roybean21 Sep 24, 2008
    my drive works on two other computers but not the laptop I use at home.
    rbean21@msn.com
please help !!
Posted on Sep 28, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Check the drive on any other system.
may be last time you were using the drive and system carsh or improper shutdown this can cause the drive damage.
Also may be a virus format the disk and try it.
Posted on Jan 06, 2008
  • Waqar Khurshid
    Waqar Khurshid Jan 07, 2008
    ok then connect the drive to the system and insert bootable CD of XP and boot the system on the installation menu where the drive is selected to install windows. there do you see any [MBR] memory if there is then delete partion of [MBR] memory and again create partion and then format it.
    best of luck.
Hello...after moving pc and take of power of WD Elements 400, it didn't show up anymore in the My Computer screen and doesn't seem to work...no sound, just the burning blue light..what to do?
Disassemble the case, and remove the 400GB disk-drive.
Connect the disk-drive as a "slave" disk-drive to some desktop computer, and see if you can still access the files.
Get the serial-number from the label on the top of the disk-drive, and access Western Digital's web-site, to check if the device is still under warranty. If it is, W.D. will replace it, at minimal cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program -- you can buy another external disk-drive from W.D.'s web-site, at a significant discount.
May 08, 2011 | Western Digital Elements (WDE1U4000N) 400...
I bought the Western Digital Elements External hard drive-500GB and it worked fine with my computer. I took it to my brother's house to download some data and his computer DOES NOT RECOGNIZE it when it's...
HI, YOU MAY WANT TO TRY, REMOVE SECURITY FROM WITHIN THE SMARTWARE, THEN AND AS ALWAYS, MAKE SURE THAT THE DRIVE, WHEN BEING CONNECTED/DISCONNECTED, THAT THE PC IS COMPLETELY SHUTDOWN.............. I HOPE THIS HELPS.........JEFFXC
Jan 25, 2011 | Western Digital Elements powered by WD 320...
WESTERN DIGITAL WBDAAR3200ABK-00 EXTERNAL HDD NOT WORKING
Every time windows tells you to format the drive, copy your data to your computer then format it. when windows detect problems on the drive, it will launch ckdsk, well i dont know hoy to fix it, try plugging it in then reboot.
May 02, 2010 | Western Digital Elements powered by WD 320...
My WD hdd was working properly till yesterday. But it was not detecting in any of the laptops around.
try change the external casing. Try with another casing(connection). try in few pc.
send to manufacturer if still under warranty.
Apr 26, 2010 | Western Digital Elements powered by WD 320...
Wester digital external is on computer not reading it
Is the drive operating normally except for the lights not working correctly?
Nov 22, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Western Digital Elements HD doing a clicking noise and no access
It might be the power adapter. I had one of these and two Maxtor external drives that just clicked that way and it turned out their adapters were bad. You can check with another adapter if you can borrow one from another drive, or use a replacement from Radio Shack. Make sure you get the same voltage and current rating marked on the original.
If the adapter isn't at fault, the small circuit board in the enclosure may be the trouble. You can remove the drive from the case and connect it to directly to a computer power supply to see if spins up properly.
If the drive still doesn't spin, it's bad. This is a common way for a drive to fail. Unfortunately, this leaves you with a drive that you can't read. Hopefully you've backed your important data up on CD or DVD.
May 21, 2009 | Western Digital Elements powered by WD 320...
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
My Elements 500 ext hard drive no longer appears on desktop
I did this on my PC. Took it to the shop (Harvey Norman). The techie reckons I got a spike across the terminals because I did not properly disconnect. He reformatted the drive for me. Unfortunately i lost everything on it (unrecoverable anyway he said). Worked fine till I got a problem with the transformer. Still working on that one. Know where to get a new transformer/power supply?
Jan 24, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Western Digital Elements Hard Drive 1TB Stopped Working!?
Western digital drives are garbage, I was using western digital drives in customers pcs and they would often come back within a week that the new disk failed. This is unacceptable as my customers need there computers and its a bad reflection on me. Now i only use seagate or hitachi and I have never had a problem with either. I strongly urge anybody that reads this to avoid western digital at all costs.
Jan 15, 2009 | Western Digital Elements powered by WD 320...
Western Digital 250GB ELEMENTS EXTERNAL USB 2.0 250 GB Hard Drive Logo
459 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
