Home | Samsung | HLN617W 61 in. Rear Projection HDTV Tel... | I HAVE A SAMSUNG HLN...
Samsung HLN617W 61 in. Rear Projection HDTV Television
Problem for Samsung HLN617W 61 in. Rear Projection HDTV Television
I HAVE A SAMSUNG HLN617W AND THE TV HAS BEEN
By johntd099 on Nov 08, 2009
I HAVE A SAMSUNG HLN617W AND THE TV HAS BEEN MAKING A GRINDING NOISE THAT JUST SEEMS TO BE GETTING LOUDER. NOW THE TV POWERS ON AND THE LIGHT BULB COMES ON FOR ABOUT TWENTY SECONDS AND THEN THE TV SHUTS OFF AND THE GREEN LIGHT COMES ON IN THE FRONT OF THE TV. iM NOT SURE IF ITS THE COLOR WHEEL OR MAYBE THE BULB OR SOMETHING ELSE??
Solution #1
posted on Nov 08, 2009
Not Rated)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 855 votes
Here is what I would do if I was you.
Remove the lamp---it is customer removable---- The color wheel will be able to be seen--it will face the front of the lamp.
In case you do not know the color wheel is a round plastic wheel with different colored segments--
What you are looking for is are any or most of them shattered--anything short of the complete wheel will cause the lamp to go off---set will detect the wheel not moving correct and shut lamp off---color wheel turns at over 12,000 rpm.
Some sets you may need to use a small mirror to see the wheel.
If it is damaged you can based on your model number find one on the internet--lots of places sell replacements.
There are also several sites that have printed and even Video instructions for the replacement of the wheel--this is the least expensive way to get this fixed. Most of the wheels run from about 90 -130 dollars plus shipping.
Confirm actual model number and VERSION number that will be on a label on the right side and or the back of the set.
I am here to help people--let me know if you have any questions.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Was this helpful?
Yes
No
Popular Solutions for Samsung HLN617W 61 in. Rear
Questions and Unsolved Problems for Samsung HLN617W 61 in. Rear
Do you recommend Samsung HLN617W 61 in. Rear Projection HDTV Television?
Answer
Answer
Wont come on...it cycles 3 times and then the standby light comes on.
Answer
It is powering itself off.. It will turn back on ,but turns off again in a few minutes
Answer
have a 63" dlp model HLN617W and its making a grinding noise it turns on then shuts itself off... (More)
Answer
samsung flat screen keeps turning off...sound stays on...what is the problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung HLN617W 61 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
