Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic tx-47p950a
The Rear Projection picture has gone red and seem to have very Green in the picture, this faults seem to get better with in been on for a hour or so.
4 Suggested Answers
  • 3130 Answers
SOURCE: Panasonic blue convergence problem
Yea, you have to have the two convergence Amp IC's replaced. Should run you about 300 bucks or so. Good Luck
Posted on Sep 14, 2007
  • 133 Answers
SOURCE: Panasonic Rear Projection TV - PT-47WXC43G Convergence Problem
The tube should be ok its the IC's regulating the convergence is your problem . A tv repairman should be able to repair it fro around $250.00 - $300.00 or less depending on who you call. Good luck
Posted on Mar 01, 2008
  • 4234 Answers
SOURCE: 3 flashing led
That model number does not come up as valid for me. Is this set in Europe?
Posted on Jun 18, 2008
  • 65 Answers
SOURCE: Blue & green star like spots on Panasonic rear projection LCD TV
The EEPROM needs to be reprogrammed. You should contact Panasonic customer care as they may fix this at no charge to you.
Posted on Aug 09, 2009
0 characters
1 Points
My television has suddenly turned into double picture thts gone red and green..y is this? and can it b fixed.
try the auto convergance inthe viseo menu, if not it is the convergance board not a good idea to replace
May 30, 2010 | Panasonic PT-47WX49 47" Rear Projection...
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
46 Picture issues.
The Digital bd has gone bad and needs to be replaced. Part# is BP94-02065A
Jul 09, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Broken screen
Parts Dist Cititronics / Panason St Louis Mo
1 800 846 2484.
please give me a rating for this info.
Jan 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
3 flashing led
Jun 18, 2008 | Projection Televisions
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Projection Televisions
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Sony kp-51hw40
Yes you have bad green and red crt but with an adjustment you can still use it. remove the front panel and you'll see the focus pack (it;s a black piece with 6 rotating knobs on it. Adjust clock otherwise the red and green screen (the bottom line knobs) till the lines has gone. The better way to check it is to adujt in video input with no signal, just black screen.
Nov 06, 2007 | Sony KP-51HW40 51" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
