Question about Canon Rebel XT / EOS 350D Digital Camera
CF pin eos 350D one of the pins for the compact flash card connection has bent flat. can I repair it?
  • 667 Answers
I'm afraid they break most of the time. You can try it though since the repair involves replacing the board that the connector is soldered to, $$$
Posted on Jan 06, 2008
6ya staff
SOURCE:
When the Compact Flash Card is inserted into the EOS camera a pin has bent over and a message reads "Error CF". Please advise cost to correct. Forgive me, but I am securing more than one quote...
Is it the compact flash card that has a pin bent? If so, I would replace the card with a new one. If the pin on the camera is damaged, then service at canonusa.com or 1-800-OK CANON is indicated.
Feb 12, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Bent pin when replacing cf card in rebel xti now card won't seat in properly.
if camera pins are bent then CF card want sit properly you have repaire CF unit.
Aug 01, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Err cf have changed compact flash cards. every
check deep inside the card slot to see if you have any bent pins. They can often be straightened out with a thin screwdriver.
Sep 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D CF memory card won't go into slot
It sounds like you have some bent pins in the card slot. Take it to a reputable camera repair and they can look and tell you for sure.
May 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350D
I don't have a 350D, and don't have a list of codes but I would guess the error code refers to the Compact Flash card. In the instructions to my camera, a 400D, the solution is to remove and reinstall the card, if there is still a problem, you might have to format the card. Hopefully this will help!
Sep 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Digital Rebel XT / EOS 350D
I had the same problem; I could insert the card but it wouldn't read. I Got a CF error message. I was going to get it fixed then I realised that the bent pin was touching the adjacent pin. So I intentionally broke-off the damaged pin... an now it works perfectly! Many of the pins on CF cards don't appear to function.
Obviously, only do this if the pins are touching and you can't bent the pin back straight. You could make thing worse by rummaging aroung the CF slot, but as I was going to send it away anyway, at some considerable cost, I had nothing to lose.
Sep 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon camera has error cf
Of course you have tried to format the CF card ? That can solve the problem.
If you get err 99 when trying to format the memory card, the problem is probably in CF (Compact Flash) connector. One common reason is bent pin. You can see it when looking into card slot.
Another possibility could be the CF connector terminations inside the camera. I repaired one EOS 350D where solder joint in one of the pins (23rd) was broken. And that looked like manufacturing failure in the printed circuit board (see the picture). The solder pad for that pin was far too small. There can be also other such cases in the market. The disassembly of the camera is rather difficult but if you have some experience on that kind of work, it is worth trying when you have no other option. Some guidance for disassembly can be found for example here: http://astro.ai-software.com/articles/mod_350D/mod_350D.html
Aug 03, 2008 | Canon Digital Rebel XT / EOS 350D Body...
Canon Rebel XT unable to access compact flash card
check all the pins in the CF socket in the camera are there, or are not bent, repair is expensive if broken
Jan 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
141 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
